strolla
Joined: 02 Jun 2007 Posts: 5 Location: New Zealand, Hamilton
Posted: Mon Jun 04, 2007 9:48 pm Post subject: distributor-im dumb |
| hey people im having trouble figuring out the order in which the spark plug leads go onto the distributor. It has no numbering to say what lead goes to what on the distributor. Hope that makes sense. Any help appreciated. |
Posted: Tue Jun 05, 2007 12:28 am Post subject: |
The firing order is 1-3-4-2 - you should find that cast into the top of the valve cover for future reference.
If the distributor is installed as it was from the factory*, the wire for #1 goes on the dist cap post that's toward the left-rear (the front passenger seat for RHD cars (intake side of the engine)), #3 is the front-left post, #4 is front-right (exhaust side of the engine), #2 is rear-right (toward your drivers' seat, assuming RHD).
*- If the distributor is installed as it was from the factory, with the tdc mark that's between two teeth on the rear of the cam sprocket lined-up with the pointer on the valve cover, the dist rotor should be pointing toward the rear-left (toward the post for wire #1).
Put your year and model in your profile so it appears at the bottom of your posts.  _________________ "..it's made in Germany. You know the Germans always make good stuff."
strolla
Posted: Tue Jun 05, 2007 1:08 pm Post subject: |
| cheers thats a big help, had trouble finding where to get that info from. Will sort it out soon. |
Posted: Tue Jun 05, 2007 3:07 pm Post subject: |
They ought to put that info on the motor somewhere. And not just a sticker, something more permanent, like engraving or something. _________________ Toofah King Bad
Posted: Tue Jun 05, 2007 4:54 pm Post subject: |
The firing order for a four cylinder car, 1-3-4-2, was passed to Moses on a tablet of stone!  _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Chrenan
Posted: Tue Jun 05, 2007 11:53 pm Post subject: |
| Rasta Monsta wrote: | | They ought to put that info on the motor somewhere. And not just a sticker, something more permanent, like engraving or something. |
Yeah, like right on top or something!  _________________ 1987 951 - M193 Version for Japan |
Posted: Thu Jun 07, 2007 1:07 am Post subject: |
Hello,
there is a marked (Engraved) line on the metall part of the distributor.Thats where your rotor should point at when the first cyl. is on OT or english TDC.All the other lines are installed counterclockwise ,following the firing order.
Nobbi  |
Posted: Thu Jun 07, 2007 8:38 am Post subject: |
| Nobbi wrote: | Hello,
All the other lines are installed counterclockwise |
???? _________________ Porsche 924 1984 (UK import) NA
Posted: Thu Jun 07, 2007 4:41 pm Post subject: |
| Ozzie wrote: | | Nobbi wrote: | Hello,
The plug leads. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Thu Jun 07, 2007 5:40 pm Post subject: |
| Nobbi wrote: | the other lines are installed counterclockwise ,following the firing order.
Yes, if you're under the car and looking up while attaching the wires to the cap (not recommended).
Otherwise, 1-3-4-2 clockwise if working from above the engine and looking down.  _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Thu Jun 07, 2007 5:48 pm Post subject: |
That might explain the miss on 2 & 3 on some peoples cars. _________________ Porsche 924 1984 (UK import) NA
Posted: Fri Jun 08, 2007 12:56 am Post subject: |
HMMMM,
depends, are you living in Aussie (Down-under) my explanation works....
Nobbi  |
Posted: Fri Jun 08, 2007 7:29 am Post subject: |
Maybe, the only car I have run across that has a dissy running CCW was a Gemini with an Isuzu motor.
Had me stumped for days why it was missing. _________________ Porsche 924 1984 (UK import) NA
Posted: Fri Jun 08, 2007 4:39 pm Post subject: |
I've got a feeling my old Triumph GT6's dizzy ran anticlockwise.
And, you're right, Ozzie, it makes things really confusing! _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
