joecitizennn
Posted: Wed Apr 18, 2007 3:31 am Post subject: GT FENDER FLARES. HOW DO THEY ATTACH??? |
| I have heard many methods of attaching carerra GT flares. Pop rivet, glue, bolt etc, but what was the factory method? How were the originals installed, and can a diagram be found of them. I know there were large gaskets that went between the body and the flare. everything else is mystery to me. |
leadfoot
Posted: Sun May 06, 2007 11:31 am Post subject: |
pretty sre they were welded as they were steel.
leadfoot _________________ 1981 ROW 924 Turbo -
carbon fiber GT mish mash
938GTNick
Posted: Sat May 12, 2007 10:13 pm Post subject: |
Steel
Threaded bolts fixed to rectangular metal inserts are molded into the Polyurethane rear arch extensions.
These are then fixed through the corresponding holes in the steel body by M6 nuts and washers.
I don't know of a detailed diagram- page 200 of the 924 parts list at porsche.com shows you the fixings. _________________ 924 Carrera GT
No. 434
(& No. 322) |
Posted: Sun May 13, 2007 1:57 am Post subject: |
LeadFoot, if you edit that real quick, nobody will see it! _________________ Toofah King Bad
leadfoot
Posted: Sun May 13, 2007 1:57 pm Post subject: |
Your letting the cat out of the bag, now how am I going to go back and put in the right answer...
Leadfoot _________________ 1981 ROW 924 Turbo -
joecitizennn
Posted: Fri May 18, 2007 3:42 am Post subject: |
I almost did that with my GT racing flares. I took a bunch of bolt stock, and cut it to 2-3" lengths, welded peices of strap metal one end. My plan was to put them on the inside of the flare and lay fiberglass over the strap metal on the end of the stud. My only problem was, once I had put all these studs on the fender flare, getting holes drilled in the body to match the studs EXACTlY, would be a nightmare. So I pop-riveted the flares on. I had to lay exra fiberglass at each rivet location, and then countersink a 3/8 hole for the rivet head. I think i used 12 to 15 rivets on each side.
If I ever have to remove the flares, I will drill out the rivets, and use bolts. The head will fit in the countersunk hole and I will just Glass it in. It should fill the same purpose, yet enable me to remove and attach the flares later in a heartbeat. |
Tigger937
Posted: Fri May 18, 2007 3:47 am Post subject: |
| leadfoot wrote: | Your letting the cat out of the bag, now how am I going to go back and put in the right answer...
Leadfoot |
BTDT  _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
Vince Ponz
Posted: Fri May 18, 2007 8:41 am Post subject: |
First let me ask, did you cut up the wheel arches?
Why did you not glue them with two part epoxy also.
Oh well, I hope they don't flex. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
joecitizennn
Posted: Sat May 19, 2007 3:50 am Post subject: |
now why would i not cut and seal my wheel arches first? I stuffed 10 inch wide tires in there. That is the whole reason for the flare man! |
Posted: Sat May 19, 2007 5:54 am Post subject: |
Wow, you Romanians have got some small tools! _________________ Toofah King Bad
