GT FENDER FLARES. HOW DO THEY ATTACH???
joecitizennn
PostPosted: Wed Apr 18, 2007 3:31 am    Post subject: GT FENDER FLARES. HOW DO THEY ATTACH??? Reply with quote
I have heard many methods of attaching carerra GT flares. Pop rivet, glue, bolt etc, but what was the factory method? How were the originals installed, and can a diagram be found of them. I know there were large gaskets that went between the body and the flare. everything else is mystery to me.
leadfoot
PostPosted: Sun May 06, 2007 11:31 am    Post subject: Reply with quote
pretty sre they were welded as they were steel.
leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
938GTNick
PostPosted: Sat May 12, 2007 10:13 pm    Post subject: Reply with quote
Steel
Threaded bolts fixed to rectangular metal inserts are molded into the Polyurethane rear arch extensions.
These are then fixed through the corresponding holes in the steel body by M6 nuts and washers.
I don't know of a detailed diagram- page 200 of the 924 parts list at porsche.com shows you the fixings.
924 Carrera GT
No. 434
(& No. 322)
PostPosted: Sun May 13, 2007 1:57 am    Post subject: Reply with quote
LeadFoot, if you edit that real quick, nobody will see it!
leadfoot
PostPosted: Sun May 13, 2007 1:57 pm    Post subject: Reply with quote
Your letting the cat out of the bag, now how am I going to go back and put in the right answer...
Leadfoot
joecitizennn
PostPosted: Fri May 18, 2007 3:42 am    Post subject: Reply with quote
I almost did that with my GT racing flares. I took a bunch of bolt stock, and cut it to 2-3" lengths, welded peices of strap metal one end. My plan was to put them on the inside of the flare and lay fiberglass over the strap metal on the end of the stud. My only problem was, once I had put all these studs on the fender flare, getting holes drilled in the body to match the studs EXACTlY, would be a nightmare. So I pop-riveted the flares on. I had to lay exra fiberglass at each rivet location, and then countersink a 3/8 hole for the rivet head. I think i used 12 to 15 rivets on each side.
If I ever have to remove the flares, I will drill out the rivets, and use bolts. The head will fit in the countersunk hole and I will just Glass it in. It should fill the same purpose, yet enable me to remove and attach the flares later in a heartbeat.
Tigger937
PostPosted: Fri May 18, 2007 3:47 am    Post subject: Reply with quote
Leadfoot
BTDT
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
Vince Ponz
PostPosted: Fri May 18, 2007 8:41 am    Post subject: Reply with quote
First let me ask, did you cut up the wheel arches?
Why did you not glue them with two part epoxy also.
Oh well, I hope they don't flex.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
PostPosted: Fri May 18, 2007 7:21 pm    Post subject: Reply with quote
i've cut the NA fenders to make room for the wheels. then i bolted the gt arches with these:
http://www.romseal.ro/parti_c/john_d/imagini/nituri.gif
using this tool:
http://www.arthur.ro/images/scule/24_mica.jpg
and then i put fiber glass all over this and then filler and paint....it looks nice..no trace of cracks or flex or anything after 1 year.
joecitizennn
PostPosted: Sat May 19, 2007 3:50 am    Post subject: Reply with quote
now why would i not cut and seal my wheel arches first? I stuffed 10 inch wide tires in there. That is the whole reason for the flare man!
PostPosted: Sat May 19, 2007 5:54 am    Post subject: Reply with quote
morghen wrote:
using this tool:
Wow, you Romanians have got some small tools!
