koolkarateguy
Joined: 16 Dec 2005 Posts: 108 Location: Nova Scotia ,Canada
Posted: Tue May 01, 2007 9:27 am Post subject: Really bad compression |
Well, I finally did a compression check tonight on my engine and it's not good. # 1 #2 and #4 cylinder are around 120 psi each. #3 is 0 , I checked it twice and it came back at 0 both times. I'm pulling the head this week . So what do you guys think ? Hole in the piston ? I'm kinda nervous about what I'm gonna find  _________________ 1979 N/A 924 |
PORSCHEV
Posted: Tue May 01, 2007 10:05 am Post subject: |
Could be a many things..... let us know if you need any help. _________________ 1976 924
1978-#53 "D" track racer. |
koolkarateguy
Posted: Tue May 01, 2007 11:08 am Post subject: |
Thanks man, hopefully it'll be one of the "many things" and not a hole. One way or another tho it'll get fixed. Shouldn't be all that hard to replace a piston in this thing.  _________________ 1979 N/A 924 |
Posted: Tue May 01, 2007 5:31 pm Post subject: |
My money's on a valve stuck open.
You can check for this quite easily just by taking the camshaft out; fixing it will mean removing the head, though. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Tue May 01, 2007 5:44 pm Post subject: |
I'm with Mike924- a valve not sealing or stuck open _________________ Porsche 924 1984 (UK import) NA
PORSCHEV
Posted: Tue May 01, 2007 8:47 pm Post subject: |
I was thinking it might be a bad cam lobe as well. If you had a hole in the piston they wil usually get alot of base pan pressure and blow out the dip stick and make a mess under the hood. Since you didn't desribe that...I dought thats the problem.
If you need another motor....I talked to a guy just outside halifax last night. You could get some parts cars for $2500.00. I would in on them with ya!
I know one looks like a trubo...but it's just the hood and nose panel vents.
http://halifax.kijiji.ca/c-cars-vehicles-cars-under-5K-1979-Porsche-924-Florida-car-W0QQAdIdZ12954043 _________________ 1976 924
Posted: Tue May 01, 2007 11:54 pm Post subject: |
I'm not sure about the cam lobe causing the lack of compression as it would have to be completely wiped out and you'd have other issues with that much metal floating in the engine.
Now, I had a lack of compression on the number one cylinder. I had concerns about that cylinder when I initially bought the car and saw that number one was missing the exhaust studs. I of course heard it running on three cylinders before popping the hood.
http://www.924board.org/viewtopic.php?t=17911&start=15
Take a look at the pictures and you'll see why there was no compression on that cylinder. |
Posted: Wed May 02, 2007 12:02 am Post subject: |
Any idea why the ex valve went like that, fiat22turbo? (And where did the missing bits go?...) _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Wed May 02, 2007 12:29 am Post subject: |
Nope, wish I did. I'm changing the exhaust out as well as the intake solution, so I'm not too concerned there. The pistons look fine at first glance, but I'll clean them up a bit before reassembly begins.
I really think it was cold air (it was raining that day) hitting a hot exhaust valve. Luckily the uber-huge valve stems are what saved the head of the valve from falling completely off. |
koolkarateguy
Posted: Wed May 02, 2007 9:52 am Post subject: |
I'm having a feeling after reading your post that I'm gonna find the same thing. Almost got the head off , just never had the right hex socket. I'm hoping to get it into the machine shop this week. Hey Fiat ? How bout some photos when she's all back together ? _________________ 1979 N/A 924 |
Posted: Wed May 02, 2007 12:05 pm Post subject: |
| fiat22turbo wrote: | | I really think it was cold air (it was raining that day) hitting a hot exhaust valve. |
That's what happens with an exhaust leak close to the head. . .on trailing throttle, cold is air sucked into the motor across the exhaust valves. . .warpage! _________________ Toofah King Bad
