isuras2
Posted: Fri Mar 30, 2007 3:15 am Post subject: Control Arm Bushings |
I have gotten the front bushings out of the control arms, but am having trouble getting the rear bushing off. Does the bushing have metal that goes around the control arm, kind of like a metal sleeve?
Thanks, _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
-nick
Posted: Fri Mar 30, 2007 5:14 am Post subject: |
I just went through this. I had a shop press them on/off and they said it was a pain -
http://www.924board.org/viewtopic.php?t=15903&highlight=control+arm _________________ 1980 931S
1991 964 C4 Cabriolet |
isuras2
Posted: Fri Mar 30, 2007 6:43 am Post subject: |
I saw that post while searching. I wonder if a bearing puller would do it...I'll find out this weekend. _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
Joined: 29 Jul 2001 Posts: 9138 Location: Royal Oak, MI, USA
Posted: Fri Mar 30, 2007 10:32 pm Post subject: |
I've used a geear splitter to grab the inner metal sleeve and then a hyd. press to push the arm out. _________________ Vaughan Scott
isuras2
Posted: Sat Mar 31, 2007 1:14 am Post subject: |
I tried a gear puller and just bent the metal, while pushing the control arm. The metal sleeve seems to be rusted/corroded onto the control arm rod. I'll keep working on it though. _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
Posted: Sat Mar 31, 2007 1:22 am Post subject: |
Yeah; depending on condition it may come off in more than one piece! _________________ Vaughan Scott
isuras2
Posted: Tue Apr 03, 2007 11:32 am Post subject: |
I used a grinder with cut-off wheel to cut through the metal sleeve. Then I used a screw driver to get the sleeve off. I only made very minor scratches on the post. Now if I can only get the rivets off for the ball joint... _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
leadfoot
Posted: Tue Apr 03, 2007 4:55 pm Post subject: |
drill them out, first with a 2mm pilot bit then the rest with a 5mm bit IIRC... the head should just pop off when you get the right size bit...
Make sure you center the pilot bit well, the rivot are quite hard metal too.
Leadfoot _________________ 1981 ROW 924 Turbo -
carbon fiber GT mish mash
Posted: Tue Apr 03, 2007 9:53 pm Post subject: |
I usually use an air chisel on the rivets, easy to pop the heads off, just be careful to not damage the arm. _________________ Vaughan Scott
