Hello, need some advice...
PostPosted: Sun Mar 25, 2007 8:39 pm    Post subject: Hello, need some advice... Reply with quote
Hello,
i am dealing with an engine problem.
My engine is running only on 3 cyl. instead of 4.The 2nd one is cutting out.
I have a good ignition timing and spark on all 4 plugs.Also the gas is coming good through the lines.The engine fires and starts like normal but only on 3 .......
When i pull the sparkplug 3 are lightly coloured black and the one from cyl.2 is wet from gas.
Help will be appreciated.
Nobby
PostPosted: Sun Mar 25, 2007 9:01 pm    Post subject: Reply with quote
change the plugs first. or you could also swap the spark plug from No.2 with No.3 for example..to see what happens.
PostPosted: Sun Mar 25, 2007 11:16 pm    Post subject: Reply with quote
It also wouldn't hurt to pull that injector and chcek the spray pattern - it's possible it's peeing fuel instead of spraying a proper mist.
PostPosted: Sun Mar 25, 2007 11:40 pm    Post subject: Reply with quote
Hey,
i changed the plugs and ckecked the spray pattern.Looks ok.
But still not running.A couple of weeks ago the garage adjusted my valves,could this have some kind of affect ?
PostPosted: Sun Mar 25, 2007 11:51 pm    Post subject: Reply with quote
I'd do a compression check next.
PostPosted: Tue Mar 27, 2007 6:25 am    Post subject: Reply with quote
Hey,
did a compression check, it is about 7 bar on the 2 nd cyl.
couldnt check the other ones .But it looks like the compression isnt to bad.It should run atleast with the others.
What are youre rates on an ok-running car?
Have- to -drive-Z3-Nobbi
PostPosted: Tue Mar 27, 2007 7:08 am    Post subject: Reply with quote
dude i have over 11 bar on all cyls. 7bar is bad. sorry i think you have a bad cyl
moone924
PostPosted: Tue Mar 27, 2007 10:31 am    Post subject: Reply with quote
put in a jumper in instead of the fuel pump relay and pull the injectors. Make sure none of them are spraying. They should only spray when the sensor plate is moved. I had a similar problem once when there was a small tare in the diaphragm in the fuel distributor on my NA 924. The small tare let enough gas through to flood out one of the cylinders.
Ryan Moone
New philosophy : one car project at a time.
moone924
PostPosted: Tue Mar 27, 2007 10:38 am    Post subject: Reply with quote
that's about 100 psi.... which is low by euro standards, my old early engined USA 924 NA only had 90psi across the board.
Ryan Moone
-nick
PostPosted: Tue Mar 27, 2007 1:11 pm    Post subject: Reply with quote
90psi? Wow! A 7.5:1 931 will push over 110psi.
7 bar is really low for your engine. Check the other cylinders.
1980 931S
1991 964 C4 Cabriolet
PostPosted: Tue Mar 27, 2007 2:08 pm    Post subject: Reply with quote
Suprisingly, Porsche's tech specs actually show 6.0 bar as the wear lower limit - and for all 924NA-931 engines regardless of CR.
There's some stuff here on doing dry, then wet (with oil) compression tests - http://www.924board.org/viewtopic.php?t=18382&start=7
Sometimes you can have a sticky piston ring that affects compression, and a top-cylinder cleaning with a detergent like MMO (Marvel Mystery Oil) may loosen it up. Actually, the wet part of the compression test might even free it up. These procedures will produce clouds of smoke though, so don't do it in a garage - or even outdoors near homes that have windows opened.
Top cylinder cleaning can also remove carbon deposits - more detail on that here - http://www.924board.org/viewtopic.php?t=18019
PostPosted: Tue Mar 27, 2007 11:48 pm    Post subject: Reply with quote
Thank you folks !!
I learned a lot more and do check it again.
Let you know when on the road again!
PostPosted: Wed Mar 28, 2007 1:21 am    Post subject: Reply with quote
Hmm, at least you have compression on all four cylinders! Mine has no compression on number 1 (I'm dreading pulling the head for fear of finding a holed piston or worse)
