Posted: Tue Mar 06, 2007 1:47 pm Post subject: 2" guage upgrade |
I got these oil,volts,water from
http://www.iequus.com/products.php?category_id=100_105
There back lit with a choice of 4 colors
red.blue.green,yellow. Awesome _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
endwrench
Posted: Tue Mar 06, 2007 2:32 pm Post subject: |
Just put a set of these in for a customer. Seem like pretty fair quality for the cheap price. I've seen a whole lot worse.
Posted: Tue Mar 06, 2007 4:28 pm Post subject: |
I dont know 60 bucks there selling on E-bay for
alot more. I like the backlighting. & the easy readable
numbers there mechanical though. _________________ 1979 porsche 924 Na
Martijnus
Posted: Wed Mar 07, 2007 10:00 am Post subject: |
i've bought this brand once for my motorcycle, good stuff and indeed cheap
average of 25 eur over here (about 35+ dollar or so?) _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Posted: Wed Mar 21, 2007 11:26 am Post subject: |
Got them in today though the center console isnt in maybe tonight though wed. most likely ..guages hooked up easy enough the oil sender fit
the volt guage fit for the water the water temp I bought some
raditor puty stuff its a 2 part clay that you knead together made by
J_B weld the water temp sensor fit perfectly in the thermo time switch
hole with the lip of the sensor fitting tight so it was an easy fix.
I started up my car tocheck for leaks there were I forgot to scrape off
the rear coolant flange on the head so i did that and applied more
hylomar I use a different coolant flange with a fresh gasket last time I used some form a gasketwith hylomar you can remove the part and put it back on its a non harding gasket sealer.. so on restart oil jumps up
to 41 pounds and stays there from at idle adn when I rev it up its gone up to 60 so Im getting good pressure.. volts read at 14
after a few minutes the water temp went up to 160 degrees and stayed..
Posted: Wed Mar 21, 2007 8:03 pm Post subject: |
i'm waiting to see a gallery of pictures with your car...interior/exterior all togheder.  _________________ Supercharger and EFI kits
Posted: Thu Mar 22, 2007 2:55 pm Post subject: |
Are you you think Im gonna do that.. maybe... I rechecked my
oil pressure today seems like it idles at 50 psi and goes up to about 63
at 2700 rpm ..thats just sitting in the garage reving. _________________ 1979 porsche 924 Na
Posted: Sat Mar 24, 2007 1:38 pm Post subject: |
Man Iget low oil pressure at idle ... water temps is around 175.
pressure top Ive had is 65 67 thats just city driven. Saturday
Im goin out on the freeway in the afternoon gotta go deliver
stuff to Terri at the hospital. _________________ 1979 porsche 924 Na
Posted: Sat Mar 24, 2007 2:48 pm Post subject: |
Mine is very low at idle too when warmed up. The manual says that the OP light coming on is normal after hard driving. . . _________________ Toofah King Bad
