How-To - waste a full day on a simple problem
Goto page Previous  1, 2
PostPosted: Thu Mar 22, 2007 4:15 am    Post subject: Reply with quote
Yeah I thought some of ya's had an easier time with the large gauges..
Actually, I can just barely squeeze my hand up-in behind the dash to push out the left and right side gauges, but the lambda processor and relay (mounted below the steering column) are show stoppers for removing the speedo from the center.
So, as long as you don't have the o2 sensor system ("lambda"), you should have access to all three including room to reach and unscrew the speedo cable from behind the dash.
MGQ
PostPosted: Thu Mar 22, 2007 11:12 am    Post subject: Reply with quote
Thanks everybody- I just want to remove the left side one, I haven't done it yet but I'll let you know how it goes, I had thought maybe they all three came out at the same time, but if I can just do the one that will be great.
Brown 78 924. 4 speed, AC, Sunroof
Vince Ponz
PostPosted: Thu Mar 22, 2007 11:31 pm    Post subject: Reply with quote
You don't need no stinkin lights. Just listen to the exhaust. Maybe I should have typed "badges". From Treasure of Sierra Madre. Ahhhh you guys are too young.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
PostPosted: Fri Mar 23, 2007 2:42 am    Post subject: Reply with quote
Badgers? We don't need no stinking badgers!
PostPosted: Fri Mar 23, 2007 11:26 am    Post subject: Reply with quote
I'm a PSU fan, but since I live in WI, Bucky is needed here....
MGQ
PostPosted: Fri Mar 23, 2007 11:58 am    Post subject: Reply with quote
Got it all working, all I had to do was push on the gauge from the backside and it popped out, the bulb was actually good but the connector was loose, thanks guys
Page 2 of 2
