91rocco
Joined: 20 Mar 2007 Posts: 10 Location: nottingham,uk
Posted: Thu Mar 22, 2007 6:36 am Post subject: New Guy,Got a problem!!! |
Hi im new to this site so go easy on me,I have recently bought a 1979 924 and I have a story to tell,The ca had been stood for some time and needed a fuel pump so one was fitted,Now heres the small problem,When starting the car from cold it fires and splutters starts very rough,sounds flooded to me,After a few minuites it runs fine really nice!!,Leave it for half an hour and then the problems arise again,takes ages to start,starter slow then quick then stops,again sounds flooded,eventually starts rough after few minuites ticking over fine again!!!
any ideas would help,checked cold start valve seems ok???
Thanks James |
Posted: Thu Mar 22, 2007 7:06 am Post subject: |
If it is flooding while sitting hot:
Remove an injector after shutoff and see if it is dribbling gas. If yes, replace all 4 (they're cheap).
Welcome, and good luck. _________________ Toofah King Bad
Druman
Joined: 19 Mar 2007 Posts: 419 Location: Middleport, Ohio
Posted: Thu Mar 22, 2007 8:04 am Post subject: |
Hmm, sounds like you might have some sort of electical problem as well (starter is slow then fast), Check your battery terminals and grounds, a car that old could build up a lot of corrosion over the years. Hope this helps.
7osh _________________ 87' 924S non-sunroof (Red) 45K miles
PORSCHE pisses excellence... |
bruce76-924
Joined: 22 Feb 2007 Posts: 105 Location: Bradford, England
Posted: Thu Mar 22, 2007 8:14 am Post subject: |
James,
If you get real stuck and you can drive the car, you're welcome to call up and see me, I'm only in Bradford so probably about an hour and half from you.
Good luck, Bruce. _________________ 1976 924 LHD, full cage, semi tube chassis, 951 brakes, lightweight 951 body panels.
1.8t engine conversion with Holset turbo and 6 speed Audi gearbox. |
Posted: Thu Mar 22, 2007 8:16 am Post subject: |
Also pull & inspect plugs for rust. Khal's car was behaving the same after he blew his head gasket. . . _________________ Toofah King Bad
Posted: Thu Mar 22, 2007 9:22 am Post subject: |
Khal must have found a girl friend.... _________________ White 87 924S "Ghost"
D Hook
Posted: Thu Mar 22, 2007 10:30 am Post subject: |
Not if he's still blowing his own head gasket.
Well, that's no help to the original poster I guess. Sorry.
Welcome to the board.
Check your grounds. Clean 'em.
Check for dribble at the injectors as someone else has suggested already.
Good luck. Let us know what happens. _________________ '80 924 n/a SOLD |
91rocco
Posted: Fri Mar 23, 2007 4:54 am Post subject: |
| Thanks guys,I will have a look at the weekend,call me stupid but when you flick the high beam lever when the lights are off should the headlamps pop up and flash,When i pull the lever i here a relay click but nothing happens????? |
Posted: Fri Mar 23, 2007 5:23 am Post subject: |
Don't think they work that way. _________________ Toofah King Bad
Druman
Posted: Fri Mar 23, 2007 6:49 am Post subject: |
No, they don't pop up and flash, they just stay down and flash. yeah I had the same curiosity.
Posted: Fri Mar 23, 2007 6:04 pm Post subject: |
| 91rocco wrote: | | Thanks guys,I will have a look at the weekend,call me stupid but when you flick the high beam lever when the lights are off should the headlamps pop up and flash,When i pull the lever i here a relay click but nothing happens????? |
The driving lights in the bumper should flash (on a Euro-style car) when you flick the lever, so the headlamps don't need to pop up.
Is your thermo-time switch operating correctly? This should switch off the CSV after a few seconds to stop the engine from flooding. Check if the resistance at the heater terminal. If it's high (open) then there's nothing to turn the CSV off.
BTW: Welcome! _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Sat Mar 24, 2007 1:58 am Post subject: |
Hello,
i am dealing right now with the same problem.I found that one of the threats for the sparkplug is bad and the plug is not sealing the cylinder when engine is cold ! So, i gonna buy a helicoil insert retap the coil and the problem should be gone.
Good Hunting,
Nobbi  |
Posted: Sat Mar 24, 2007 7:05 am Post subject: |
| Mike924 wrote: |
BTW: Welcome! |
Dont you mean on? _________________ Porsche 924 1984 (UK import) NA
Posted: Mon Mar 26, 2007 5:05 pm Post subject: |
No. The thermo-time switch has two terminals. One is the switch contact for the CSV, the other is for a heater circuit within the the thermo-time switch.
The idea is that, when you crank, the heater warms up a bi-metallic strip in the thermo-time switch and, after 'eight' seconds, the bi-metallic strip flips and cuts of the juice to the CSV to limit the amount of neat fuel being thrown into the cylinders. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Mon Mar 26, 2007 6:51 pm Post subject: |
| Paul wrote: | | Khal must have found a girl friend.... |
I wonder if she is right handed? _________________ Porsche 924 1984 (UK import) NA
