driver1
Posted: Sat Mar 10, 2007 8:03 am Post subject: I checked the FAQ but... |
I'm looking for the power window relay, the only one I found doesn't match up to the wiring diagram, are is there a mumber on it?
Also, does anyone have or know where I can find the clips on the rear brake adjusters? a couple of mine kinda broke. |
Posted: Sat Mar 10, 2007 8:25 am Post subject: |
Power window and radio relays should be clipped to the left side of the HVAC box, accessible from the left footwell. They're both the same part number (mine are 321.919.505 25Amp) and with a little luck you'll find both there and can just swap 'em as a test. _________________ "..it's made in Germany. You know the Germans always make good stuff."
driver1
Posted: Sat Mar 10, 2007 8:47 am Post subject: |
| Smoothie, thanks I'll go check it with the radio relay. |
Posted: Wed Mar 14, 2007 6:07 pm Post subject: Re: I checked the FAQ but... |
| driver1 wrote: | | does anyone have or know where I can find the clips on the rear brake adjusters? a couple of mine kinda broke. |
Do you mean the rubber/plastic bungs in the rear back-plate?
These are recently being re-manufactured in Germany and are avaialable on E-bay. Not cheap - I'll see if I can find you a link. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
