I checked the FAQ but...
driver1
PostPosted: Sat Mar 10, 2007 8:03 am    Post subject: I checked the FAQ but... Reply with quote
I'm looking for the power window relay, the only one I found doesn't match up to the wiring diagram, are is there a mumber on it?
Also, does anyone have or know where I can find the clips on the rear brake adjusters? a couple of mine kinda broke.
PostPosted: Sat Mar 10, 2007 8:25 am    Post subject: Reply with quote
Power window and radio relays should be clipped to the left side of the HVAC box, accessible from the left footwell. They're both the same part number (mine are 321.919.505 25Amp) and with a little luck you'll find both there and can just swap 'em as a test.
driver1
PostPosted: Sat Mar 10, 2007 8:47 am    Post subject: Reply with quote
Smoothie, thanks I'll go check it with the radio relay.
PostPosted: Wed Mar 14, 2007 6:07 pm    Post subject: Re: I checked the FAQ but... Reply with quote
Do you mean the rubber/plastic bungs in the rear back-plate?
These are recently being re-manufactured in Germany and are avaialable on E-bay. Not cheap - I'll see if I can find you a link.
