Banging my head against a wall - still steamy exhaust
Goto page Previous  1, 2, 3, 4  Next
jamie924
PostPosted: Sat Jan 27, 2007 8:25 am    Post subject: Reply with quote
not sure if you have checked the valve stem seals out thoroughly but if you are experiancing smoke for the first few minuites of engine running its possible the seals were damaged when replaced and while the vehicle is standing not running oil is driping past the seals into the cylinder or cylinders and when the engine is started this is burnt off causing the smoke lesens the oil is depleated alot of the late 70s early 80s engines suffered with this the uk ford cvh engine in particular does this for a past time so the new head may cure it or it may have perished seals
best of luck
20v924
PostPosted: Sat Jan 27, 2007 12:18 pm    Post subject: Smoke the neighborhood Reply with quote
This sounds like a problem I had with a 930 in my shop. The smoke is not water! Believe it or not it is the result of a bad control pressure regulator, also called the warm-up regulator. You might be saying to yourself "but fuel smoke is black", it actually only turns black when it is incompletely burned. in this case it is burning completely because of the cold running situation the car is in. The car needs a richer mixture when it is cold but you're taking advantage of the situation! Check to see if the aux air valve is completely open when it is cold also.
A person is smart. People are stupid
PostPosted: Sat Jan 27, 2007 1:56 pm    Post subject: Reply with quote
good thing he has EFI and doesnt have a WUR then
3 928s,
Chrenan
PostPosted: Sat Jan 27, 2007 2:21 pm    Post subject: Reply with quote
or an AAV?
PostPosted: Sat Jan 27, 2007 3:35 pm    Post subject: Reply with quote
easy. . .
81turbo
PostPosted: Sat Jan 27, 2007 4:16 pm    Post subject: Reply with quote
What's with the sass?
leadfoot
PostPosted: Sat Feb 10, 2007 9:30 pm    Post subject: Reply with quote
Good news then nick, loose guide should definately have been picked up by your machinist though... sounds like whoever did the reco didn't do it properly, the head needs to be heated and the guides frozen so that when they are inserted and cooled they form a good bond... it sounds like they were just forced in... Are you getting them all done at the same time?? I would be suspect on the other guides at this point in time... and whilst you machinist is giving free services you might be able to strike a deal getting them all done...
hope it works out for you...
Leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
PostPosted: Sun Feb 11, 2007 12:06 pm    Post subject: Reply with quote
oops forgot the wink after that last comment, though it is helpfull to read all points regarding the car before making your suggestion as they could have already tried that.
3 928s,
PostPosted: Wed Feb 21, 2007 8:21 am    Post subject: Reply with quote
Is there an update, Nick? I need this story to have a happy ending. . .
-nick
PostPosted: Wed Feb 21, 2007 8:50 am    Post subject: Reply with quote
Last few weeks: temp's in the 20's F, Valentine's Day, girlfriend's brithday, out-of-town guests, work deadlines, etc.
Patience grasshopper!
Looks like I should be able to get some work done this week. I'm anxious too.
1980 931S
1991 964 C4 Cabriolet
-nick
PostPosted: Thu Mar 15, 2007 7:25 am    Post subject: Reply with quote
Sigh...
I started her up again and within a minute I got smoke. I did learn one thing - nondetergent oil smells/burns much differently than regular detergent oil. I switched the straight non-detergent 30wt oil out for valvoline 5w30. There is no doubt it's burning oil.
I took it out for a ~1 hour run around town. Once the oil started to warm, there was no smoke that I could discern. But, at my first long stoplight after starting it from cold, I got a nice smoke cloud while sitting at idle.
I took it out again last night and the smoke seems to have diminished, but it's still there. For now, I'm just going to put some mileage on it and see what happens. Who knows, maybe the rings still haven't seated. The oil control scraper ring doesn't require any seating time does it?
Otherwise, the car runs excellent. Replacing the 1st gear dogteeth made a dramatic change in the trans. I can slide it into 1st at 15mph+ with no grinds and the engagement is much more positive. The box still shifts too notchy at times, but it ain't bad!
In case anyone is wondering, here's the list of what I've done to track down this dumb smoking deal -
latest - new intake & exhaust valve guides & valve stem seals
previous -
surfaced head
surfaced block deck
head pressure tested
bored block to new pistons & rings
compression rings gapped to 0.027"
oil scraper ring left alone
piston-cylinder clearance 0.002-0.003"
new head gasket every time
head studs torqued properly
~100 miles on bottom end
rebuilt turbo - no oil in intake track
crankcase breather vents to atmosphere, no noticeable blow-by
There's not much else, eh?!
1980 931S
Min
PostPosted: Thu Mar 15, 2007 8:01 am    Post subject: Reply with quote
Thats disappointing. Does she still have oil pooling on the piston tops after sitting overnight like she did before?
Min
PostPosted: Thu Mar 15, 2007 8:59 am    Post subject: Reply with quote
Not completely sure, but I'm thinking the turbo drain side might need to have its' pressure equalized with the crankcase. -Otherwise turbo drainage might be inhibited by crankcase pressure..? Safe to assume I'm sure that you have the crankcase breather cleaned...otherwise the turbo drain would become your breather.
Other than that, and if you no longer find oil pooling on the cylinders, I'd suspect the turbo oil seal's leaking into the exhaust side. I know from personal experience after trying once to rebuild my own turbo in '96, if it's not 100% it'll fill the neighborhood with huge embarassing clouds of smoke. I drove it to the corner and back like that once, then parked it and ordered the factory rebuilt one that's still in use today.
PostPosted: Thu Mar 15, 2007 11:35 am    Post subject: Reply with quote
+1
PostPosted: Thu Mar 15, 2007 2:25 pm    Post subject: Reply with quote
as well if it isn't that cold there you could switch to a 10 or 15W base instead of a 5 that may actually help your smoke problems too.
But I would inspect the turbos drains as well.
3 928s,
Page 3 of 4
