OutOfTheBox
Posted: Wed Feb 21, 2007 1:49 am Post subject: Project Inlet Manifold - Tube or cone shaped plenum ? |
I want to design an inlet manifold from scratch using ACAD.
I want to put the plenum down at the bottom of the engine, because thats where my intercooler is, which saves me almost a meter in piping.
Also thats where the cool air is, so my plenum will be in the air running underneath the car(diverted up by the tray at the bottom of the engine ).
Anyone got any suggestions about header length, plenum volume, diffuser shape type etc.
I want to use a cone for the plenum, because I believe the optimal shape to use, is the same as you see on an intercooler. They don't use a square can at each end.
I got the actual calculations somewhere for the shape to use, I used this for a solar collector. The sun shines on a "radiator" and you pump water through it, which turns to steam, which drives a turbine.
As nearly all the plenums I've seen are tube shaped it must be because max flow is achieved with a cone plenum, but the best balance of flow is with a tube plenum ?
Anyone know why ?
I need to finish this project within 8 weeks, any help would be much appreciated. |
Posted: Wed Feb 21, 2007 2:44 am Post subject: |
My 2 cents:
The tube shaped plenum may be easiest to design/manufacture, or it may be the most efficient. . .the most important thing, IMO, is that the runners have as much volume as you can get out of them. _________________ Toofah King Bad
endwrench
Posted: Wed Feb 21, 2007 3:54 am Post subject: |
The way I understand it, the use of a tube plenum is for volume. This allows the air a chance to redirect itself to the runners and allowing for better, more even distribution.
Not real sure what you mean by a cone plenum. Are you talking a center inlet to a flat "funnel" connected to the runners? I always thought this would work well if you have the room. It is still just a large plenum with better directional flow than an end inlet tube plenum or even a center inlet tube plenum.
Maybe you could show an xample of a cone plenum.
OutOfTheBox
Posted: Wed Feb 21, 2007 4:38 am Post subject: |
| endwrench wrote: | Are you talking a center inlet to a flat "funnel" connected to the runners? I always thought this would work well if you have the room. It is still just a large plenum with better directional flow than an end inlet tube plenum or even a center inlet tube plenum.
Todd |
yes funnel/cone.
Was thinking of taking 4 x 2" 90 bends and cut the sides off, then weld them together(like the Audi Logo) so you have a 90 degree plenum, but each runners air is slightly separated.
Then use funnel shaped runners to one end. And A flat funnel the other.
I also thought of having separate runners to the end tank of my intercooler, and put the TB at the other end of the intercooler.
So that the intercooler is your plenum. |
Posted: Wed Feb 21, 2007 5:14 am Post subject: |
| OutOfTheBox wrote: | | I also thought of having separate runners to the end tank of my intercooler, and put the TB at the other end of the intercooler...So that the intercooler is your plenum. |
That won't work. . .TB shouldn't be be that far from the head, and there can't be obstructions between it and the engine. . .you would have zero throttle response, plus I don't think you want your IC under trailing throttle vacuum. _________________ Toofah King Bad
OutOfTheBox
Posted: Wed Feb 21, 2007 5:28 am Post subject: |
| Rasta Monsta wrote: | | OutOfTheBox wrote: | | I also thought of having separate runners to the end tank of my intercooler, and put the TB at the other end of the intercooler...So that the intercooler is your plenum. |
That won't work. . .TB shouldn't be be that far from the head, and there can't be obstructions between it and the engine. . .you would have zero throttle response, plus I don't think you want your IC under trailing throttle vacuum. |
your probably right, but that F1 turbo setup had its TB at the other end of the turbo, never mind the intercooler. |
Min
Posted: Wed Feb 21, 2007 7:02 am Post subject: |
and it also lived its life at wide open throttle. Drivability is a concern in your case I think. Having the throttle there would 'work'.
-nick
Posted: Wed Feb 21, 2007 8:53 am Post subject: |
The GTR had the TB before the IC too I believe. I always wondered about that, but I suppose at 80-100% throttle it doesn't matter much.
Whatever you do, use venturi's at the end of your runners inside the plenum. Makes a significant difference in flow. The one thing I regret not adding to mine. _________________ 1980 931S
1991 964 C4 Cabriolet |
As for length of the runners, unless you want to change your power-band just measure the factory runners. _________________ 1979 924 (Gone to a better place)
Min
Posted: Wed Feb 21, 2007 9:49 am Post subject: |
http://www.velocity-of-sound.com/
has a induction wave caclulator, and of course sells some very nice looking velocity stacks.
If I didn't make my own velocity stacks I'd have purchased them from there.
