Cargo area build.
Goto page 1, 2, 3  Next
PostPosted: Wed Feb 07, 2007 5:31 am    Post subject: Cargo area build. Reply with quote
Hello.
Have some nice side panels for cargo area & the start of a floating floor
with access panel for battery box. Gonna but to the sides tight up to wheel
well then go around to a raised section that runs across to each wheel well
forward of that will be speaker box of some undeturmined design.
also want to make a rear tail light cover just a cover that runs from side to side.... then sand prime & paint anythoughts or pics of what other have or have done. Show me.
PostPosted: Wed Feb 07, 2007 12:50 pm    Post subject: Reply with quote
.. made so much progress today.
I'm gonna have a really nice stereo speaker enclosure
Ill be using some fiber glass resin painted overstretched
t-shirt material the material is stretched and stapled fist
onto a larger pattern of the speaker then over the actual
pattern set above the larger one in frame.. this then has
light weight filler applied and is sanded and smoothed.
I have a floor and battery box with access cover and sides
so the cargo area is almost done.. Now Ill build a enclosure
over where the rear seats would be these will but tight to
the side panels I made that are fastened under the rear
quarter windows . I fastened the panels with machine screws
after coating the back side with a thick bead of clear silicone
to minimize noise from vibration. I also have a pretty neat
enclosure to cover the rear lights it will run from side to side
I think I'm gonna redesign the lights and have Led lights
set in the plastic housing somehow back there like maybe
mounted on the rear light enclosure I'm gonna build.
.. have pics maybe on Wednesday.
PostPosted: Wed Feb 07, 2007 1:29 pm    Post subject: Reply with quote
Did a quicke search on the net & found some pics
that will give you guys an idea of what Im doin.
check these out.
steeny
PostPosted: Wed Feb 07, 2007 2:36 pm    Post subject: Reply with quote
i'll be very interested to see what you can do in the back there joe... with almost everything else you've done looking fantastic, i'm sure this will too.
cheers
1978 924 N/A
she's gone.....
PostPosted: Thu Feb 08, 2007 8:44 am    Post subject: Reply with quote
yea thanks .. there's a endless way to mount the speakers
like a pair of nice t ts they look the best from a certain angle
So I'm looking to give them a good angle.
PostPosted: Tue Feb 13, 2007 8:56 am    Post subject: Reply with quote
Its all gonna be blue.
Ill make a 42" x 14" cover with a 10" sub in the center & something on the sides instead of doing what in this pic below. I was thinking of standing the 10" sub up and building a barral on its side goin towards the back with the front tilted up the full circumfrance of the circle showing
the back would be lower maybe only half way above cover.
what ever I put on the sides will be tilted inwards I guess. Im using this technique as in the pic below again.
PostPosted: Tue Feb 13, 2007 9:34 am    Post subject: Reply with quote
Joe you're on a fabricating spree just pray to god you never have a short/spark around. Other than that...looks great !
PostPosted: Tue Feb 13, 2007 10:35 am    Post subject: Reply with quote
Yes.. an allnighter last night.. sparks or short ..hm-mm there
really nothing back there to short or ground is there..
Got to fill and sand and prime do that this week & build
a tail light cover lets see then make a new center console
with new gauges (oil pressure, volts, water temp, air fuel mix)
next week pull the dash and do some repair then put it all back
together Then deal with the seats.. & a shaved door handle kit
I also still have to put the duct in my hood paint it put lights in the bumper,
attach hatch latches switch to 944
hatch get the rear wheels done.. lots and lots of things here.
Yea I'm gonna spend a few hundred and get some nice speakers
subs amp receiver..
Bought the sub already(waiting on delivery) and have an amp.
The receiver needs to have a CD writer & a US or some kind of
port so I can listen to stuff I get off the inter-net. phheeeww a mouth full.
Hows your car Morghen.
PostPosted: Tue Feb 13, 2007 8:41 pm    Post subject: Reply with quote
hey good to see that you have the time and skills to do all this. cant wait to see the car finished.(btw the new paint scheme looks awesome !)
my car is waiting for some funds...going to set the weel alignment soon then add some music to it and a central locking sistem. when it gets warm i'm going to paint the nose section again...since i trashed it a while a go i repaired it but did not paint it yet...so funds funds funds
steeny
PostPosted: Wed Feb 14, 2007 11:11 am    Post subject: Reply with quote
if i was to do something like this, i would probably try to leave the whole back level all the way to the front seats. Then put the subs in the wells where the seats were. possibly a fibreglass mold of the seat area so I could have some truly sealed enclosures. looks like there would be heaps of room. plenty of sound deadening so that nothing rattles too. then carpet the whole thing.
but then, i'm not too worried about being able to see the subs, they are really only there to reduce background noise. Perhaps one day i'll have the time and money to really have a go at a project like this.
what are you going to do for a spare tyre?
1978 924 N/A
she's gone.....
PostPosted: Thu Feb 15, 2007 2:13 pm    Post subject: Reply with quote
Spare tire that's a good one m8 never worried about
having one before wont start now .. I spent almost all day
filling & sanding today... the bottom piece is one piece the
center line there is just a pencil drawn center-line..
Boy waite till you guys see the top of the speaker
cabinet its gonna be sweet all right.
N-Dub
PostPosted: Sun Feb 18, 2007 8:44 am    Post subject: Reply with quote
Joe, it looks great!!! Just remember with the subs, it is all about there ability to move air. And are you going to do something like what Porschev did to where your rear seats used to be?
'79 924 now Totaled! Carrera GT bodywork for sale!
'87 951
PostPosted: Sun Feb 18, 2007 10:44 am    Post subject: Reply with quote
I primered the cargo build yesterday .once you do that you
find that things show up requiring more filling
& sanding..
On the box for the subs it needs to be a air tight box right
the sub come with directions on box size and ideas on how to build it.
steeny
PostPosted: Sun Feb 18, 2007 10:47 am    Post subject: Reply with quote
depends on the subs. some need a fully enclosed box, others need a ported box.
just make sure the volume is as close to right as possible, otherwise many of them sound bad.
cant wait to see more pics
1978 924 N/A
she's gone.....
PostPosted: Sun Feb 18, 2007 2:59 pm    Post subject: Reply with quote
The sub needs a box totaling one cubic ft of space ive been told I could use one cubic foot of water if I have a funny shaped box you know
to get the right volume. Im going with a sealed box. pics Ill have some monday
Page 1 of 3
