geddes66
Joined: 10 May 2003 Posts: 129 Location: Bakersfield CA
Posted: Thu Feb 01, 2007 1:59 pm Post subject: Blown pressure accumulater gas all over |
Vital info: 1977 NA 4 speed Built Sep. '76
Today, I had to bring the Pcar home after it was down for the trans getting stuck in 2nd and having to drop, repair and re-install that. While I was under it I noticed a little fuel seeping from one of the two cylindrical assemblies plumbed in right after the fuel pump. I am assuming they are the pressure accumulators. Because of this, I used a car I had borrowed from a friend untill today and did not drive it... untill today. My commuter is out of the body shop and I had to get home.
I figured I could limp it home.
NOT!!!!
So now it is on the side of the road. It had gas dripping from all over the area around the accumulator in question. I was very lucky there was no fire. The accumulator is toast.
The question is: Can I remove the bad accumulator and the "T"'s then install straight brass connectors in the fuel line thus running it on just the single accumulator untill I can get it home?
I need an answer soon. (before the tow truck) _________________ The Porsche is now my son's, my car is cooler, slower but cooler. |
Posted: Thu Feb 01, 2007 2:07 pm Post subject: |
the fittings on there are a special thread, in order to bypass it you will have to cut the hoses and install a straight through which will allow you to run the car, but you will need to replace all that hose after that point.
but it would be a good idea to replace that hose anyways due to age. _________________ 3 928s, |
geddes66
Posted: Thu Feb 01, 2007 2:54 pm Post subject: |
Thanks Lizard, I think the PO did alot of cutting and changing to hoseclamps so that shouldn't be a big deal. _________________ The Porsche is now my son's, my car is cooler, slower but cooler. |
Posted: Thu Feb 01, 2007 4:24 pm Post subject: |
You should upgrade to the single larger unit. _________________ Porsche 924 1984 (UK import) NA
Posted: Fri Feb 02, 2007 3:48 am Post subject: |
| Once upon a time, one of the car mags did an article on just that -- European car I think in the late 90's had a 924 as a project car and they did a series of articles, one of which was converting from 2 20cc accumulators to 1 40cc accumulator or something like that. Also might be something in the FAQ's |
81turbo
Joined: 03 Nov 2002 Posts: 1065 Location: Oakland, CA
Posted: Fri Feb 02, 2007 7:56 am Post subject: |
| pm sent about a 40cc unit. |
