heater core
Benino
PostPosted: Thu Jan 18, 2007 2:40 am    Post subject: heater core Reply with quote
My 1980 931 needs a heater core. Trying to find a non dealer source.
I found a site that shows this:
924: 1982 Heater Core, from 924 VIN#92 CN450832 & 924T VIN#93 CN150332
Is there some reason this heater core only lists for 1982? will it not fit?
the picture looks right:
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
Chrenan
PostPosted: Thu Jan 18, 2007 2:46 am    Post subject: Reply with quote
I think there were major changes to the 924 ventilation system some time close to when the 944 came out (1983 model year), so this may have something to do with it. One of the better 924 historians here will know (gohim, paul, etc).
PostPosted: Thu Jan 18, 2007 3:03 am    Post subject: Reply with quote
I take it yours is leaking? I have had a coolant odor since I changed the hoses to the core, but I can't find any leaks up front, and am wondering if I pushed too hard on the fittings while pressing the hoses on.
FWIW, PET also shows a series of ">>Chassis Number" but only shows one part number for the core. Superceded?
PostPosted: Thu Jan 18, 2007 3:15 am    Post subject: Reply with quote
AHA!
Our Very Own Tech Section wrote:
2 - Late 924/931 (late '82-onward) Details
The late 924 and 931 cars benefitted greatly from the early introduction of the 944 HVAC system, which was far more efficient than the old system. If you have one of these cars (924 VIN 92 CN450832 onward and 931 VIN 93 CN150332 onward) you will need to be sure to get the correct parts when servicing the system. Parts suppliers often do not know or correctly identify the differences, so compare and be sure the parts are the same part number as the 83-85 944. The differences extend to the heater control unit, which is the 944 style.
Based on this, I would say the bit you found might not work.
-nick
PostPosted: Thu Jan 18, 2007 3:52 am    Post subject: Reply with quote
The pipes from the heater core out to the engine bay are much shorter on the late'82+ cars. The late'82+ have the hoses from the head clamp onto the heater core on the interior side of the firewall. From what I remember, the earlier cars have the hoses clamp on the engine side of the firewall.
Basically, you'll need to extend your hoses to make it work. I used a pair of brass male-male barbed fittings and some extra length of hose. It's ugly, and uses lots of hose clamps, but works fine.
I believe the hose diameter of the later core is slightly larger too. Make sure your hoses are soft and pliable or else they'll crack when you try and put them over the core.
Have fun. This job sucks!
*edit - just so you know, this is the core I'm using. The issues above are the only problems
1980 931S
1991 964 C4 Cabriolet
Benino
PostPosted: Thu Jan 18, 2007 3:57 am    Post subject: Reply with quote
I called them and they also list this same part for 87-88 924s. So I called the porsche dealer. They could not tell me if they are interchangeable, but they do show a different part number for 80 924 and for 87 924s . . . so unless someone here has tried this replacement, there's no way to know
It may be a typo but the site was letting me complete the order for $37 shipped for the heater core I found:
http://www.tweeks.com/shop?frame=6.4061
The correct heater core for 80 931 ordered from the dealer will take 3-4 weeks and cost over $300 at the wholesale price.
Benino
PostPosted: Thu Jan 18, 2007 4:07 am    Post subject: Reply with quote
I didn't see nick's post until after my last one. So you are saying the core itself is the same size and will fit in my heater box?
I replaced my heater core in my 80 N/A a few years ago. I cant' remember where I got the core or how much it cost, but I do remember that what I installed in the car had much shorter plastic tubes and because of this it was a huge pain to install the hoses and clamp them on.
The core that was originally in the car was the same setup as the one I just pulled from my 931. The core has a plastic flange with two water holes and then a separate plastic piece with flange and two tubes. You stick the tube piece through the firewall before sliding the heater core into the heater box, and then you bolt the flanged tubes to the flange on the core. This allows for longer tubes since they aren't int he way when you are trying to slide the core in.
-nick
PostPosted: Thu Jan 18, 2007 5:37 am    Post subject: Reply with quote
Yep. The version with the bolt-on tubes carries the ridiculous pricetag. The 944 core with the shorter tubes is cheap, but as you found out - a real pain to install. Other than the tubes, they're essentially identical.
1980 931S
PostPosted: Thu Jan 18, 2007 5:44 am    Post subject: Reply with quote
So Benino, where is yours leaking? Is it repairable?
Benino
PostPosted: Thu Jan 18, 2007 5:52 am    Post subject: Reply with quote
What actually broke was one of the bolt on tubes. cracked near the base which I could not tell until I had removed it all. Thats where the big leakage was coming from. The core is also leaking out of the middle and looks pretty crusty and corroded along the edges too. if it didn't look so crusty I'd probably consider having it repaired, but it looks like it could spring another leak any time.
PostPosted: Thu Jan 18, 2007 5:56 am    Post subject: Reply with quote
Maybe you should run it by the radiator shop and see what they say. The bolt-on tube (477 819 869) is $4.54 and the two sealing rings (021 101 173) are $4.08 each.
rasta
924guy
PostPosted: Thu Jan 18, 2007 9:53 pm    Post subject: Reply with quote
late 82 924/924T have the early 944/late 924S ventilation system as stated above. my 931 , which has a build date of 10/81 but was not delivered until 9/82 has the late system and its a huge improvement over the earlier set up. my defrost actually defrosts, heater actually heats, ect. !
when replacing the h/c always replace the hoses, its a pita to do and you know if you dont they will leak in short order
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
steeny
PostPosted: Fri Jan 19, 2007 6:48 am    Post subject: Reply with quote
this part breaks all the time, and is a bitch to get at. i ended up repmacing the bolt on bit and the two sealing rings as rasta mentioned. a grand total of 9 bucks or so from pelican.
cbass was looking at making aluminium versions of the two tube bit, though i think it sorta got shelved in preference of more power.
the most annoying part of the whole deal is that the whole dash has to come out
1978 924 N/A
she's gone.....
-nick
PostPosted: Fri Jan 19, 2007 7:07 am    Post subject: Reply with quote
29 years of deposits in the cooling system - I would venture a guess that a replacement core would improve the heating system. The HVAC needs all the help it can get on the early cars too! It might be worth just swapping the whole core out.
1980 931S
PostPosted: Fri Jan 19, 2007 11:30 am    Post subject: Reply with quote
I had a radiator shop install my old end tank on the new cheaper core for $25.
Here's a before picture:
http://im1.shutterfly.com/procserv/47b5db10b3127cce91b21f6c9f2700000016108AZuGrlozZtE
