Posted: Wed Jan 03, 2007 4:51 am Post subject: |
i see lots of people are converting to CGT body.
hey ! soon we're all gonna have CGT cars !  _________________ Supercharger and EFI kits
Posted: Wed Jan 03, 2007 7:45 am Post subject: |
Alternator mounts, fit the air con, respray, decals. _________________ Porsche 924 1984 (UK import) NA
endwrench
Posted: Wed Jan 03, 2007 2:39 pm Post subject: |
| skemcin wrote: |
I don't have the time nor the cash to touch my 8k mile 79 - its sitting in a nice warm garage like it has for the last 20+ years.
Just curious, what would you do if you had the time and cash? Replace a lot of rubber?
Todd |
djeviltwin
Posted: Wed Jan 03, 2007 4:10 pm Post subject: Happy New Year |
My poor 82 is still sitting... My major plan is to get it running again.
I've gotten the little stuff (starter and fuel-pump relay) but now it's not turning... I'm going ro pull the battery again as my charger broke and I think it damaged it. If that's good I'll get a direct line to the sylinoid and try that. I may end up taking it in to a shop as I just don't have the time to trace all the electrical... I'll then re-do the interior and get the body work done. Summer will be a good time for me. _________________ 1982 924 ~pics coming.... soon |
skemcin
Joined: 02 Sep 2003 Posts: 1284 Location: Plainfield, IL
Posted: Wed Jan 03, 2007 10:52 pm Post subject: |
| endwrench wrote: | Just curious, what would you do if you had the time and cash? Replace a lot of rubber?
Todd | yep - that is the first order of business with that car is replace all the rubber and drain/refill all the fluids (including the gas). No one, including myself, has tried to start the car in 20 years - but its been kept in a dry garage the whole time - its a beautiful car.
 _________________ 924.org (no time to complete)
9249206347 - 8k – waiting its resurrection, no power at the fuel pump and fuse #7 blows w/power |
Chrenan
Posted: Thu Jan 04, 2007 12:57 am Post subject: |
For 2007:
Upgrades:
Euro Bumpers (Done)
250 lb Weltmeister Springs (Done)
Lower rear
New Centre Console
Black Carpet
Roll Bar
Harnesses
New Slim Hi Flow Rad Fans
Maintenance:
Oil Change
Tranny Oil Change
Timing Belt and Tensioner Change
Swap out small accumulator for large one (I cheaped out on this repair a few years ago ) _________________ 1987 951 - M193 Version for Japan |
Raceboy
Posted: Thu Jan 04, 2007 1:52 am Post subject: |
On my 931:
*Finally get it going, the delay is been due to lot of work and university sudies at the same time + VEMS installs on other cars (yeah, not nice )
Have to get the FMIC welded together and finish the 3" SS exaust. That should be all. And of course, tune the VEMS on it.
*On my wifes 83' NA.
-VEMS install (done)
-Full '86 951 rear axle conversion w/ yellow Konis and alloy arms. It has Konis but new suspension is going in together with the rest of the stuff.
-924 "GTP" conversion. Includes 2.5 16v Turbo engine (S2 head + 951 lower end with double cam sprocket conversion). I have the 951 engine and S2 head is in the shop right now (full-radius valve-job w/ new valves, porting etc). Also 924 crossmember (that is modified to accept 944 engine),951 TT and gearbox which I already have.
In the end of January I receive black leather seats from 94' 968.
And finally I have to finish the engine rebuild of my friends 924 "GULF" racecar. For that I need to receive some items from NEMESIS first. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Posted: Thu Jan 04, 2007 1:55 am Post subject: |
- Head work - valve job, cam, port & polish
- Cooling System - water pump, t-stat, fan upgrade, new hoses & radiator service
- M471 sway bars
- Strip hood insulation
- Hook up 3rd brake light
- Replace hatch and door glass rubber
- Get my flippin OP gauge working
- Find some Pasha cloth to repair my seats
- Enjoy my new brakes, wheels & tires at PIR!
- Arrive San Diego in the 2007 Porsche Parade's most Shaggalicious 931
Last edited by Rasta Monsta on Fri Sep 07, 2007 4:19 am; edited 2 times in total |
924aussie
Joined: 02 Feb 2006 Posts: 1009 Location: Chinchilla Queensland Australia
Posted: Mon Jan 08, 2007 9:12 pm Post subject: |
944 front fenders
make parts out of the molds I am buying, spoiler mold, rear flare molds, sill molds, bonnet scoop mold & bumper molds (924 CGT)
May even add some cubic printing or sometimes called water transfer printing, or aquagraphic processing ! maybe a totally wooden or marble 924
Alan _________________ green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1980 Fire truck Sold |
CBass
Posted: Thu Jan 11, 2007 12:12 pm Post subject: |
A little more fanatical weight savings... A little more bodywork.
Brake R&R, throw a rebuilt set of 5 bolt calipers on, have my rotors turned, rebuild one of my master cylinders, set of those EBC ceramic pads...
New tires, AVS ES100 225/50/15 on the spiderwebs.
Finish making my strut tower bar and fuel rail (never enough hours in the day)
Finish my EFI conversion(still waiting on the ignition stuff)
Throw in the new strut mounts, balljoints, tie rod ends etc I`ve had sitting around for months... Replace the front end bushings with polyurethane bushings from a Rabbit kit.
Once that´s all up to spec I´ll likely think about ordering a 3.0 16v and 6 speed from 20th St. _________________ '81 931 in various states of assembly |
JakeFrame
Joined: 28 Feb 2006 Posts: 93 Location: Ohio zip- 43501
Posted: Thu Jan 11, 2007 2:01 pm Post subject: Whats that? |
20th street? _________________ 1976 924 Automatic- Body Only
1977 924 4 spd Red~For Sale~
1977 924 4 spd Yellow~For Sale~
1977 924 4 spd
1992 Mercedes 300e 4MATIC |
Posted: Thu Jan 11, 2007 2:16 pm Post subject: |
on my 81 928 with 86 engine,
Convert to MSII V3 w/ EDIS,
custom install ITBS, and two turbos, with air air intercoolers.
Possibly convert to HID headlights. _________________ 3 928s, |
angeloz
Joined: 11 Jan 2007 Posts: 19 Location: New York State
Posted: Thu Jan 11, 2007 2:58 pm Post subject: |
I think I may try to replace my throwout bearing and then just drive it as it needs nothing _________________ 1980 Porsche 924 Special Edition
40K miles - showroom new - 2nd owner |
Posted: Thu Jan 11, 2007 11:56 pm Post subject: |
2007 started...and i did this until now:
- add oil as some got consumed
- add water as some got evaporated or leaked trough the pump.
- install rear seats back into the car + carpets + trunk noise izolation
- set the clutch pedal to engage a bit higer as it was a PITA to drive
- replace headlight motor...the lights poped up but did not get down(arnold )
planing to buy and install 17" weels and new fuel pump soon.
also planing(for some time now) to install a 924T intercooled engine&tranny.
In the end i wish to repaint the nose section of my car as i've trashed it and i had it remade. _________________ Supercharger and EFI kits
356speedster
Posted: Fri Jan 12, 2007 5:50 am Post subject: |
- Wheel bearings
- Bushings
- Shocks/spring (Lower it slightly)
- New CV joints
- 16" wheels/tires
- Make it water proof (new seals)
- Restore the gasoline heater
Make it a good daily driver for next winter, so I don't have to freeze my ass off because the only reliable daily driver at the moment is the Fiat cabriolet  _________________ 1982 Porsche 924 na My 924 blog
1990 Porsche 928 S4 My 928 blog
1995 Fiat barchetta
2007 BMW 318d M-Sport
2010 Volvo V50 |
