Wheel Bearing howl or just not enough grease?
billmay34
PostPosted: Wed Jan 10, 2007 2:27 am    Post subject: Wheel Bearing howl or just not enough grease? Reply with quote
New Years greetings to all!
The Purple Martini has a wheel howl! We are submitting our information here in hopes of sage advise.
Symptoms: Wheel noise when rolling that quiets down upon steering changes.
Response so far: purchase new bearings and attempt removal and install of new bearings.
Problem: now that the wheel and brakes and transaxle are disassembled we are having a heck of a time getting the splined axle out of the original mounting. All of this makes us consider if perhaps the original howling was the result of a poorly adjusted/tightened crown nut on the axle our insufficient lubrication in the first place. The general area is coated with a fine dust of a rust coloration that might indicate that lubrication and proper tightening of the crown nut was the main problem.
Is there an easy way to remove the splined wheel post? As long as we are in there we will renew the bearings and then reassemble with appropriate amounts of lubrication.
If anyone here has any words of wisdom (or pity) we hope you will share your advise and expertise.
Pictures at: http://s144.photobucket.com/albums/r177/billmay34/wheel/
Bill May
Seattle, WA
1991 MB 300E - 202,000 Miles
1977 Porsche 924 Martini - 85,000 Miles, Purple.
PostPosted: Wed Jan 10, 2007 2:37 am    Post subject: Reply with quote
there is just abit of corrosion in there, take a 2x4 and hold over the end of the shaft so as not to damage the threads and get a 20lb sledge hammer and give it a couple of whacks it will come out.
3 928s,
PostPosted: Wed Jan 10, 2007 6:06 pm    Post subject: Reply with quote
I see you're wearing the correct safety footwear for that sort of job.
PostPosted: Wed Jan 10, 2007 6:13 pm    Post subject: Reply with quote
Better than mine.
PostPosted: Wed Jan 10, 2007 6:15 pm    Post subject: Reply with quote
LOL
rusto
PostPosted: Wed Jan 10, 2007 6:37 pm    Post subject: Reply with quote
Use a big 2 legged puller or if you're going to hit it, take the trailing arm out and support it from behind or you'll be shocking the suspension.
billmay34
PostPosted: Wed Jan 10, 2007 7:31 pm    Post subject: Damn thing stuck solid! Reply with quote
I beat the H*** out of the spline and no movement. Then I checked for in-out, left right, up down movement and decided to reassemble with a boat load of grease on the CV joint and spline.
the noise is diminished yet not gone. i will post a UTUBE link for your listening and diagnostic pleasure. i hope someone will have some advise for us.
the BFH did not budge the spindle!
Bill May
Seattle, WA
PostPosted: Wed Jan 10, 2007 7:45 pm    Post subject: Reply with quote
Well then I'd say its either cooked or rusted in and it should not be back on the road till fixed.
The short shaft comes out but needs more force.
This is what is supposed to come off
PostPosted: Wed Jan 10, 2007 11:42 pm    Post subject: Reply with quote
Yea with those short shafts
you should of been able to knock them out.
I replaced both sides, inner and outer a while back
Sage advice hmmm never heard that before.
http://www.geocities.com/Heartland/Farm/7478/sage-adv.htm
PostPosted: Thu Jan 11, 2007 12:13 am    Post subject: Reply with quote
I've never had a hard time getting them out - just a little work with a hammer, but then mine might be a little worn...
spiraloutse4n
PostPosted: Thu Jan 11, 2007 5:35 am    Post subject: clip? Reply with quote
ozzie, in the picture you posted it looks like theres a circlip there.. where does that go? could it be holding my spline in place?
PostPosted: Thu Jan 11, 2007 5:41 am    Post subject: Reply with quote
...if they howl they might do what mine did & thats come apart
then the balls would get stuck and a very loud 'Bang' noise
could be heard the first time that started happenin scared
me ...thought
I was getting shot at lol.
PostPosted: Thu Jan 11, 2007 5:47 am    Post subject: Re: clip? Reply with quote
Seems unlikely. . .here's a pic:
-nick
PostPosted: Thu Jan 11, 2007 5:57 am    Post subject: Reply with quote
The circlip just holds the rear bearing in from what I remember.
I've used the piece of wood between the shaft and a hammer with success. You just need a little more oomph Or a pick up a big gear puller from your local auto parts tool exchange program. Around me, both Autozone and Advanced Auto have them.
1980 931S
1991 964 C4 Cabriolet
PostPosted: Thu Jan 11, 2007 6:00 am    Post subject: Reply with quote
Hmm, mine both slid out like they had bearing grease all over them, must be the low mileage on the car.
