OT-Maserati Biturbo
ossaman55
PostPosted: Mon Jan 08, 2007 12:10 pm    Post subject: OT-Maserati Biturbo Reply with quote
I have a chance to buy a 84 maserati biturbo cheap and was wondering if anyone has had any experience with them.
Darren
1980 931
1984 Maserati Biturbo
1978 Triumph Spitfire
1986 Camaro Z28
PostPosted: Mon Jan 08, 2007 12:18 pm    Post subject: Reply with quote
Do you have AAA? Plus, or regular?
PostPosted: Mon Jan 08, 2007 1:16 pm    Post subject: Reply with quote
IIRC that beast has a blow through Weber 2barrel carb!
PostPosted: Mon Jan 08, 2007 1:21 pm    Post subject: Reply with quote
http://home.att.net/~mabc/specs.html
PostPosted: Mon Jan 08, 2007 6:04 pm    Post subject: Reply with quote
May seem cheap now, but wait 'til you have to buy parts for it.
924guy
PostPosted: Tue Jan 09, 2007 1:18 am    Post subject: Reply with quote
cool car, ive been tempted myself a few times , as they can be found dirt cheap, but as said above, parts and costs are huge hurdle for most. a $600 bi turbo can cost more than one cares to think about to get in order. dont invest more in one than you can afford to throw away.
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
PostPosted: Tue Jan 09, 2007 1:50 am    Post subject: Reply with quote
Some of these prices seem pretty similar to 931. . .
ItalianCarParts.com wrote:
Biturbo
AC Compressor with clutch, new: #mabt015 $1,069.95
AC Compressor clutch only, new: #mabt015c $695.50
AC Compressor rebuild kit: #mb3155208rk $149.95
AC thermo knob, knob only: #mb315520432 $14.50 ea
Air Filter Box Strap: #mb312420100 $19.95 ea
Alternator Fan Blade replacement, all Magneti Marelli: #20418 $19.95
Brake light switch: #mb313320187 $39.95
Brake master cylinder, rebuilt: #ma317420103r $425.00*exchange
Bushing update kit: #mb9530 $285.35 ea
Carb rebuild kit, through 1985: #mb312230016 $89.95
Note: additional items not included with kit are listed below.
Carb base gasket: #mb312220422 $8.50 each (requires 2)
Plenum gasket: #mb31220301 $29.50 ea
Float assembly: #mb312225324 $57.95 ea
Carb rebuild kit, 1986 on: #mb10016 $94.50
Carb base gasket: #mb3222210422 $12.50 ea
Plenum gasket: #mb3222210301 $29.50 ea
Float assembly: #mb10324 $59.95
Choke cable: #MB318227114 $148.50
Clutch Slave Cylinder: #mbcs $149.95
Crank Seal: #MB311020368 $27.95 ea
CV Joint Boot: #0404 $28.95 ea
CV Joint Clamp Set: #3415 $7.95 ea
Hose, master to clutch slave: #mb318220112 $34.95
Convertible Top Latch, specify Driver or Pass when ordering: #mbttl $199.95 ea
Drive Shaft Center Support: #mb20101 $273.50 (Specify ID 40 or 45mm)
Distributor cap, carb, V6, through 1985: #mb313220202 $89.95
Distributor rotor, for above: #mb313220203 $49.95
Distributor cap, injected, V6, 2 coil wire, 1985 & on: #mb313220221 $269.95
Distributor rotor, for above: #mb313220222 $189.95
Distributor Pick-up: #mb20214 $119.95
Engine Top Gasket Kit. Heads, Cams, O-rings. #MBTHGS $429.50
Expansion tank, cooling system, all Biturbo models: #MB554021102 $69.75
Front Fender, New, Original, Left or Right: #BTFF $429.50 ea
Fuel filter, not 86: #mb319253125 $54.95
Fuel filter, 86 only : #mb312220100 $24.95 ea.
Fuel Sender with gasket, in tank unit: #mb31362 $94.95
Fuel hose: #BTFH $21.75 per foot
Fuel pump: #BTFP100 $329.95
Gear Shift Knob, Wood, New: #BTWGSK $79.95
Head Gasket Set, 228/2.8L, 331/2.5L: #MB37008 $379.50
Intake Gaskets: #MB312020329 $24.75 per gasket
Top end gasket set, 228/2.8L, 331/2.5L: #MB37008 $598.00 set
Key blank, Trident, ignition, Biturbo models: #BT51104 $26.50 ea
License Plate Lamp, Complete Assembly: #MA20212 #49.95
Lift-O-Mat Trunk Compartment Strut: #4915 $69.95 each
Oil Filler cap: #MB9601 $89.95
Oil pump rebuild kit: #MBOPRK $189.95 kit
Oil pump, Front engine seal kit: #MB820320 $42.95 kit
Oil seal kit, Front portion of engine, 3 oil seals: #MB35507 $49.95 kit
Rebuilt Differential, Biturbo models: #MBTRD $1,529.50 + 350.00*exchange
Turbo, Turbine Center Cartridge, New, Specify 74 or 75mm: #MBTTUR $599.95
Rebuilt Turbo, Biturbo models: #MBTRT $929.95 + 250.00 core*exchange
Rebuilt Water Pump, Biturbo models: #MBTRWP $295.00 + $75.00*exchange
Starter, Biturbo models, Magneti Marelli, (core exchange required): #3134 $399.95
Strut, front engine lid, all Biturbo models: #MB314320122 $67.95 ea*exchange
Strut, rear trunk lid, all Biturbo models: #MB7314201182 $67.95 ea*exchange
Strut, front, shock insert, Biturbo models: #MB862329 $250.00 ea
Suspension, control arm: #MB316620114 $74.50 ea
Suspension, control arm nut: #MB128360140 $2.50 ea
Suspension, Lower ball joint: #MB20103 $62.50 ea
Suspension, stabilizer drop link: #MB571 $69.95 ea
Manual steering rack, Biturbo through 1984: # MBRSR-M $395.00*exchange
Power steering rack, Biturbo 1985 & on: # MBRSR-P $475.00*exchange
Tie rod end: #MB21324 $44.95 ea
Thermostat, small, 70c, Biturbo models: #MB314020109 $69.95
Thermostat O-ring, small thermostat, Biturbo models: #MB314020331 $6.75
Throttle cable assembly: #MB318220009 $199.95
Throttle cable Ball-Pin: #MB31842116 $39.95 ea
Timing Belt: #MBTTB1 $79.95
Timing Belt tensioner bearing: #MA311020107 $89.95
Turbo Intake Gasket, 2 required for #MBTRT: #MB0307 $14.75 set
Turbo Outlet Gasket, 2 required for #MBTRT: #MB0303 $18.50 set
Valve adjusting shim, 2.005-4.500mm in increments of .005: #MB-shim $12.95 ea
Valve guides, intake or exhaust: #MBVG $15.45 ea
Valve, intake, 23mm: #MB310620450 $32.50 ea
Valve, intake, 27mm: #MB310620451 $32.50 ea
Valve, exhaust: #MB470032002 $32.50 ea
Valve cover gasket, per side: #MB311020321 $32.95 ea
Water Coolant Fitting, all Biturbo models: #MBTWCF $29.95
Water Pump, Biturbo models: # MBTRWP $295.00*exchange
Wire set, Biturbo, OEM: # MB20213 $159.00
PostPosted: Tue Jan 09, 2007 1:54 am    Post subject: Reply with quote
Hey, actually, why not get two? I am a little tempted myself after reading reviews in the link posted by Paul. . .
ossaman55
PostPosted: Tue Jan 09, 2007 7:11 am    Post subject: Reply with quote
Yeah, im definetly leaning towards buying. Does anybody know if it is an interferance engine. The owner thinks it may have jumped time. It has less than 100,000 miles on it, its rust free and it has a complete spare engine with 41,000 miles on it. the only problem is i have too many cars as it is and will be leaving for college in the fall.
Darren
1980 931
1986 Camaro Z28
Rooy
PostPosted: Tue Jan 09, 2007 9:22 am    Post subject: Reply with quote
I've seen this question come up a few times on another message board I frequent. Have a look here:
http://archive.mirafiori.com/show.php?fid=2&msg=144247#2_144247
http://archive.mirafiori.com/show.php?fid=3&msg=85596#3_85596
It appears that at least some years had an interference engine.
Andrew
Neenah, WI
'78 924 with dual Dellortos
ossaman55
PostPosted: Wed Jan 10, 2007 7:26 am    Post subject: Reply with quote
it seems as if i have been sucked into the maserati mix. Im going to look at in the next day or two but he has lowered his price to the point where i cant refuse. Plus the 0-60 in six seconds was hard to turn down:D
Darren
1980 931
1986 Camaro Z28
Neil924
PostPosted: Wed Jan 10, 2007 8:15 am    Post subject: Reply with quote
Don't kick the snot out of an old car, it'll cost ya.
924guy
PostPosted: Wed Jan 10, 2007 8:21 am    Post subject: Reply with quote
hmmm, isnt that what old cars are for??
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
PostPosted: Wed Jan 10, 2007 12:11 pm    Post subject: Reply with quote
Don't kick any Italian car, it will crumple into a pile of rust.
PostPosted: Thu Jan 11, 2007 7:19 am    Post subject: Reply with quote
I just watched the Top Gear episode on this car (Series 6, Episode 2). A complete piece of shite, according to Jeremy Clarkson -who loves Maseratis, by the way.
He bought one and then dropped a dumpster full of steel on it from 100 feet. He called it, "...an affront to one of the best badges in the business."
