Ghost wipers
79porsche
PostPosted: Fri Jan 05, 2007 2:17 am    Post subject: Ghost wipers Reply with quote
Test drove the car last night and suddenly the wipers sweeped across the windshield all on their own....I checked the switch lever and the wiper was in the off position. It was as if the switch was suddenly moved to "intermittent". I toggled the wiper lever switch several times but never could find a position where the wipers would completely stop sweeping.
Also...the wiper switch seems to have the following postions:
High -- Low -- Off -- Intermittent
However, even on the best days when the wipers don't have a mind of their own....the wiper motor never seems to not run in high speed....only low speed or intermittent.
Anybody seen this before? Is it the switch? Relay? or motor?
Thanks for the help!
PostPosted: Fri Jan 05, 2007 2:35 am    Post subject: Reply with quote
you will need to clean/fix the ground to the steering column,
and the wiper arm is high, low, off, int.
3 928s,
PostPosted: Fri Jan 05, 2007 2:51 am    Post subject: Reply with quote
The wiper-turning-themselves-on is a grounding issue - ground for the wiper switch is completed through the screws that hold it on. The plate that the screws go through and make contact with is zinc plated. The zinc plating oxidises over time, degrading the ground. Then while driving, you hit a bump or make a turn and the conductivity through the ground changes, which signals the wiper relay to initiate a wipe. Quick fix (, but you'd have to go without the automatic wiper park and wash cycle) is to pull the relay. Better fix is to remove the steering wheel and clean just the spots behind the wiper switch mounting screws, then reinstall with toothed washers or/and dielectric grease to inhibit any more oxidation.
Also look here - http://www.924board.org/viewtopic.php?t=17996&start=03
The slow wiping problem can be oxisized connections anywhere from the switch - fuse/relay panel - wiper motor. I posted an easy test here - http://www.924board.org/viewtopic.php?t=17884 With that you can diagnose whether it's an internal motor problem or wiring/connections.
968rz
PostPosted: Fri Jan 05, 2007 8:04 am    Post subject: Reply with quote
I had this same problem when I first got my 24. I went so far as to add a ground wire (small gauge) from the switch thru the column to a dash ground, never had a problem since (almost 10years)
Rick
PostPosted: Fri Jan 05, 2007 8:15 am    Post subject: Reply with quote
Had similar problems but it was caused by the faulty wiring of the PO.
PostPosted: Fri Jan 05, 2007 11:28 am    Post subject: Reply with quote
might also be worth having a read of this
http://www.924board.org/viewtopic.php?t=21013
Lightning22
PostPosted: Mon Apr 16, 2007 9:07 pm    Post subject: Reply with quote
That advice has just saved me hours of work. Thank you.
Rich
PostPosted: Tue Apr 17, 2007 2:36 am    Post subject: Reply with quote
Ghost wipers in the sky...?
