Weltmeister Springs - which way is up?
Chrenan
PostPosted: Fri Dec 29, 2006 1:26 am    Post subject: Weltmeister Springs - which way is up? Reply with quote
I picked up some Weltmeister 250 lb springs. I didn't realize they were progressive, does anyone know which way is up when they are installed? They look like the picture below. Do the more open coils get installed facing down as in the picture? This would make sense to me.
-nick
PostPosted: Fri Dec 29, 2006 2:21 am    Post subject: Reply with quote
I have the compressed springs on the bottom. There may be an argument for having them on the top, as it would be slightly less unsprung weight (lots of coils moving at the bottom, as opposed to fewer coils moving at the bottom). I don't really think it matters though!
1980 931S
1991 964 C4 Cabriolet
Chrenan
PostPosted: Fri Dec 29, 2006 3:27 am    Post subject: Reply with quote
The way you have them installed makes sense when you consider the writing printed on the springs would be the right way up with the compressed springs on the bottom. I was never much good at Physics, but I just assumed it made a difference which way they went in.
PostPosted: Fri Dec 29, 2006 4:03 am    Post subject: Reply with quote
Many moons ago, when I put progressive springs in my old Bimmer, we installed them the way they're pictured in your first post, with the tight coils at the top.
Never really thought about why. As I recall, it's just the way the supplier said to put them in...
Min
PostPosted: Fri Dec 29, 2006 4:45 am    Post subject: Reply with quote
I have some of those springs installed on my 931 chassis, the tight coils are on top. I got the car with them installed that way.
Min
PostPosted: Fri Dec 29, 2006 5:02 am    Post subject: Reply with quote
Not to hijack the thread, but should I install a pair of these while my front suspension is apart?
The options are:
  • 220 lbs Stock Height Springs
  • 200 lbs Performance Springs (Lowers Car About 1.25 Inches)
  • 250 lbs Autocross Springs (Lowers Car About 1.5 Inches)
TIA
PostPosted: Fri Dec 29, 2006 5:50 am    Post subject: Reply with quote
hmmm both ways make sense to chrenen Nick seems to have a good theary, Khal has them the other way.. as mins cam that way....thewn theres the hi-jacker someone call weltmeister Ill call them.
PostPosted: Fri Dec 29, 2006 5:57 am    Post subject: Reply with quote
I called paragon and left them a message & my number.
I called back a few minutes later and talked to Chuck
and he said it doesnt matter you can put them in either way
though if you put one side one way the other side has to be the same
other than that... either way doesnt matter.
Heres Chucks number 1-361-289-8834 paragon products.
Chrenan
PostPosted: Fri Dec 29, 2006 6:16 am    Post subject: Reply with quote
Thanks Joe and everyone else, I thought it might be a stupid question, glad to know it wasn't too stupid!
flosho
PostPosted: Fri Dec 29, 2006 6:37 am    Post subject: Reply with quote
Guess I'm a lil late, but I have the 250# 1.5" lowering springs and I put the tight coils near the top.
I don't think it matters which way though.
[This Space For Rent]
PostPosted: Fri Dec 29, 2006 6:46 am    Post subject: Reply with quote
The options are:
TIA
Of course it's entirely up to you depending on what you want to do with the car.
I put in a set of the 220lb stock height springs - mainly to fix a front tire rubbing problem on turns with 911 Fuchs wheels...those springs along with a stiffer stabilizer bar are what got the job done. They're not as long as the OE springs, so once you get the OE springs compressed and out, you no longer need to use a spring compressor (the 220lb springs are loose in the strut assembly when it's reassembled - until you have them back on the car and the car back on the ground).
PostPosted: Fri Dec 29, 2006 6:49 am    Post subject: Reply with quote
a friend of mines installed progressive springs on his corrado with the tight coils down and when he hits a bump or smth they make a crappy noise...so i think they should be installed with the tight coils upwards.
PostPosted: Fri Dec 29, 2006 8:57 am    Post subject: Reply with quote
Shall we turn the post into a poll ..'lol'.
endwrench
PostPosted: Fri Dec 29, 2006 2:31 pm    Post subject: Reply with quote
Every set of stock progressive springs I have put in (many!) always called for the tighter coils on top. I don't know why either. JMTC
Todd
