is anyone running 9.5:1 pistons ?
augidog
PostPosted: Sat Dec 16, 2006 11:57 pm    Post subject: is anyone running 9.5:1 pistons ? Reply with quote
I'm just wondering if they are the same as the Euro's with just a better quench.I may install some on my daily driver. I'm just putting out some feelers. I'll be going all stock except the new pistons.
Thanks
Min
PostPosted: Sun Dec 17, 2006 3:17 am    Post subject: Reply with quote
all 924na's have pretty bad squish area, becuase the pistons sit so low in the block, and don't have very large dishes in the pistons, Becuase they sit so low (3-5mm) down in the block, technically they don't really have any 'squish'
Min
Vince Ponz
PostPosted: Mon Dec 18, 2006 8:54 am    Post subject: Reply with quote
I have them in my car.
Vince
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
PostPosted: Tue Dec 19, 2006 3:03 pm    Post subject: Reply with quote
I have 9.5:1 cossies in the basement
endwrench
PostPosted: Wed Dec 20, 2006 4:18 am    Post subject: Reply with quote
I run 9.5:1 compression with 8.5:1 pistons. Block is decked .050"
Todd
PostPosted: Wed Dec 20, 2006 6:24 am    Post subject: Reply with quote
block deck..there ya go that ll give you a bump
before my pistons went I had 9.0-1 and I felt
the difference on the freeway from 8.5 anyway
suppose you could go with a nos kit with a blow off valve.
augidog
PostPosted: Mon Dec 25, 2006 12:36 am    Post subject: Reply with quote
The set I'm looking at are standard bore FINISHED HONED SIZE, 86.520. for $100 without rings.
What is the likelihood that I won’t need a re-bore? I have two original engines.
Chrenan
PostPosted: Mon Dec 25, 2006 1:46 am    Post subject: Reply with quote
The 77 block I used for my rebuild was not running when I got it, came out of a car with unknown mileage and unknown maintenance that had clearly been abused based on the condition of the body and running gear. The machine shop I brought the block to said they had never seen a used block with such nice bores, the factory cross hatching was clearly visible. They just did the minimum (hone or re-applied the cross hatching, something like that) and I was good to go. That was the first time I really bought into the theory that the 924 bottom end was "bullet-proof".
Min
PostPosted: Mon Dec 25, 2006 5:19 am    Post subject: Reply with quote
I've opened 4 924 motors so far, and all of them have the factory crosshatching visible. I've also had machinists mention that the rods are huge.
Min
endwrench
PostPosted: Tue Dec 26, 2006 5:59 am    Post subject: Reply with quote
Mine had 130,000 miles and rust in the cylinders and it cleaned up great. I have NO oil usage.
Todd
