m8782538
Posted: Tue Nov 28, 2006 1:35 am Post subject: Speedo cable, Bonnet/ Hood pins |
I have to replace the speedo cable as it has broken somewhere, i have no idea where to start, has anyone else done this who could give me some pointers?
Bonnet/Hood Pins, the release cable has gone so i am going to fit some pins, not too sure where to fit them though, has anyone else fitted them if so where or where would you recomend putting them? |
Posted: Wed Nov 29, 2006 5:52 pm Post subject: |
The best places to check the speedo cable are at either end; one where it connects to the speedo head and the other inside the nearside hub cap. Most probably one or other of these ends has come loose, rather than an actual break in the cable.
Bonnet pins?!! On a Porsche?!! Are you sure?!! Replace the cable! _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
968rz
Joined: 21 Aug 2006 Posts: 537 Location: S. E. Wisconsin
Posted: Wed Nov 29, 2006 6:07 pm Post subject: |
+1 for what mike924 said. It may also help to know (if you don't already) that the speed sensor is attached to the front wheel so jacking up the front and spinning the wheel can help to trace the problem. _________________ Rick
93 968 coupe Amazon Green 4spd Tip (my DD) |
m8782538
Posted: Wed Nov 29, 2006 8:43 pm Post subject: |
the cable has broken near the actual speedo, i can actually remove part of the cable from the speedo end.
I am fitting bonnet pins because it is not the actualy cable that has broken, the spring and retaining bolt has broken inside the secureing mechanism, this you have no access to therefore i cannot fix it, the only choice i can see is bonnet pins. |
Posted: Wed Nov 29, 2006 8:51 pm Post subject: |
There is a place in the UK where they can make up any speedo cable to any specification (standard or custom) for quite reasonable money. They advertise in Practical Classics. I'll look them up for you when I get home. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Wed Nov 29, 2006 11:47 pm Post subject: |
So the latch is broken? Can't you just replace the broken components? Surely there's a VW breaker not far away... they're certainly nothing special!
Just say NO - to rice!!! _________________ Vaughan Scott
Chrenan
Posted: Thu Nov 30, 2006 12:58 am Post subject: |
I second what Vaughn said, if the spring inside the release mechanism in the hood is broken, replace the whole mechanism with a good used one. That isn't exactly a rare part. If you just fit hood pins you will become the "Previous Owner" or "PO" everyone here complains about. Trust me, you don't want to become that person. _________________ 1987 951 - M193 Version for Japan |
Posted: Thu Nov 30, 2006 1:00 am Post subject: |
^^+1 _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Sun Dec 03, 2006 4:15 am Post subject: |
Ive put in 2 cables the first one wasn't sealed up good enough
so the cable rusted and broke, after that the one I put in
got
a kink from installation and it ended up breaking too.. I
tried to fit a later model cable too. It has 2 cables a long
& a short & a box that both cables go into in between the wheel
& the back of the speedo. Think it came out of a 924S. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Mon Dec 04, 2006 5:58 pm Post subject: |
| Mike924 wrote: | | There is a place in the UK where they can make up any speedo cable to any specification (standard or custom) for quite reasonable money. They advertise in Practical Classics. I'll look them up for you when I get home. |
Sorry, forgot to look at the weekend! My mind was on preparing the car for it's MoT this morning... If things go smoothly, I'll look up the info tonight. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Tue Dec 05, 2006 6:04 pm Post subject: |
OK, despite the disappointment of my car failing the MoT (cracked anti-roll bar mount), I still remembered to look up the details of the speedo cable people:
Speedograph Richfield Ltd.
Rolleston Drive
Arnold
Notts NG5 7JR
Tel.: 0115 926 4235
Fax.: 0115 920 9912
email: info@speedographrichfield.com
web.: www.speedograph-richfield.com _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
BC77-924
Joined: 06 Jan 2004 Posts: 84 Location: Glacier Park, British Columbia Canada
Posted: Thu Dec 07, 2006 12:43 am Post subject: Speedo Cable |
Mine has broken in the same place twice. Just go out and buy a speedo cable for a VW Beatle or Old Karmann Ghia, it is the same thing. Regular Porsche price on the item was just under 100 dollars. The Beatle cable you can buy on E Bay for about 15. Good luck.
Darrel _________________ Silver/Grey 77.5 |
Posted: Thu Dec 07, 2006 5:54 pm Post subject: |
That's useful to know. Thanks, Darrel. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Fri Dec 08, 2006 6:31 pm Post subject: |
Bonnet catch assembly here on E-bay, m872538. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
m8782538
Posted: Sat Dec 16, 2006 1:12 am Post subject: |
| it's the lower part of the catch, the part fitted to the slam pannel. I have fitted bonnet pins now, it's an easy option, i can always fix the problem later on and fit a new bonnet. |
