Dash project
Goto page Previous  1, 2, 3, 4, 5, 6, 7
Desolation
PostPosted: Wed Sep 20, 2006 2:34 am    Post subject: Reply with quote
Ah, I thought the fleece would like flatten out on the 4 sides
1977 924 - sold
1989 Mustang
My MySpace ^_^
dan476
PostPosted: Wed Sep 20, 2006 10:48 am    Post subject: Reply with quote
you staple it to round portions and you stretch it, that way it becomes round
Desolation
PostPosted: Wed Sep 20, 2006 11:09 am    Post subject: Reply with quote
Oh! I got it now, I'm a little slow.
1977 924 - sold
1989 Mustang
My MySpace ^_^
Mike B
PostPosted: Fri Sep 29, 2006 10:52 am    Post subject: Reply with quote
Hey Dan...How's the project going. I've been following your effort with great interest.
PostPosted: Fri Sep 29, 2006 2:41 pm    Post subject: Reply with quote
Not bad ... what do you think, you dont want drink holders
Im gonna make one probly this winter and its just gonna be the same as the old except bigger I want the 3 guage cluster only with bigger guages.
Im gonna build a frame and use colored laminate glued on with black
vinyl & foam .
dan476
PostPosted: Fri Sep 29, 2006 8:42 pm    Post subject: Reply with quote
hey guys,
My project is stalled right now, it got cold outside and i do not have a garage. I am going to start work on my engine and wiring and whenever it gets warm/or i get a garage where i can fiberglass, then i will continue on. i got some new ideas but again i cannot do much right now. I'll let you guys know whever i make a progress and i will resurect this thread then.
Desolation
PostPosted: Sat Sep 30, 2006 6:36 am    Post subject: Reply with quote
Aw man, I was waitin to see one of your projects completed
1977 924 - sold
1989 Mustang
My MySpace ^_^
924fanatic
PostPosted: Sat Sep 30, 2006 7:19 am    Post subject: Reply with quote
Same here
Currently being restored:
Porsche 924, 1976, Red
Mike B
PostPosted: Sat Sep 30, 2006 11:12 am    Post subject: Reply with quote
Thanks for the update Dan...You should come to sunny Calgary...I think we got up to 24 C today and highs are expected to reach around 26 C tomorrow
Desolation
PostPosted: Sat Sep 30, 2006 12:28 pm    Post subject: Reply with quote
Its about 56 C here give or take a few
1977 924 - sold
1989 Mustang
My MySpace ^_^
robermar
PostPosted: Tue Oct 10, 2006 1:51 pm    Post subject: Reply with quote
Dan, if that's you in the avatar, then I have seriously misjudged you....
One Eyed Wheeler
PostPosted: Wed Oct 11, 2006 1:47 am    Post subject: Reply with quote
Wow Dan I am totally inspired!!!
Keep up the good work
Such friendships are priceless, and such friendships are forged only through shared experiences (and often, hurdles) from which loyalty and wonder spring. Such friendships are rare. Such friendships are common on the Gumball.
caswah
PostPosted: Sun Oct 29, 2006 2:58 am    Post subject: Nice job! Reply with quote
Great job!
When I redid my dash, I didnt smooth it with filling foam like you did - a mistake by me.
Im inspired and I might redo my center console in the same way, but I think I would use MDF with thin walls (5mm ~1/4 inch) and glass fibre. Gonna do some Photoshopping and see what might come out...hehe.
Good Luck with your project!
Euro ´81 924 - Interior being restored
jamie924
PostPosted: Sat Nov 18, 2006 2:07 am    Post subject: Reply with quote
as an alternative to the fleceing have any of you guys seen bendy mdf you can get it in b and q sotres in the uk in 4ft by 2ft sheets or make it yourself by getting a sheet of 5-6mm mdf and using a circular saw cut 2-3 mm slits in the sheet all the way across the width of the sheet about 6-8mm apart so it looks like a sheet of lined paper hey presto it bends 2 layers of that would be perfect for the bullet enclosures with plenty of pva i say 2 as if they are used as sealed rather than reflex (vented) enclosures there will be alot of pressure inside the box also maybe add a brace in the center if you are gonna be using them real hard some of the compitition spl 10 inch woofers can produce upto 20 tonnes pressure inside a sealed box also a router on a jig can be used t cut really accurate circles in mdf rather than a jigsaw thus creating a god seal fra sealed enclosure
that said i do find the fleace idea interesting and think i might give the dash a go and add it to the long list of bits i have to do
PostPosted: Sat Nov 18, 2006 8:19 am    Post subject: Reply with quote
Thin MDF (5mm) bends real easy, just wet it a little and put pressure on it. When it dries it retains its shape.
Slow process but it can be done.
Page 7 of 7
