Badeu
Posted: Mon Sep 18, 2006 12:53 am Post subject: EFI conversion |
Cause there is a lot of topic about this, and because i'm planning to buy another 924 head to make an EFI conversion.
I would like to know if someone has good informations on how to mounts injectors ( I have some 310 cc out of a MAZDA MX-6 ) and wich fuel rail is best suited for 924.
thanks. |
Min
Posted: Mon Sep 18, 2006 3:44 am Post subject: |
how you mount the injectors will depend on the type of injector you have.
As for the fuel rail, you have to build it yourself. Or have it built.
leadfoot
Posted: Mon Sep 18, 2006 10:48 am Post subject: |
Use bungs in the CIS injector holes and an extruded tube for the rail...
The other option is using a quad throttle body setup from a toyota corolla 4AGE... you would need to make an adapter plate for the runners but it would have the housing for the injectors and you could use the same model fuel rail as a package... just swapping out the injectors...
Mins right in the sense you would need to check whether you injector are side feed, top feed or barb ended... the 4AGE use (normal) double ended O ring... IIRC
Leadfoot _________________ 1981 ROW 924 Turbo -
carbon fiber GT mish mash
simsport
Joined: 06 Nov 2002 Posts: 573 Location: UK Warrington
Posted: Tue Sep 19, 2006 3:18 am Post subject: Weber Alpha |
Weber make an injector cap and clip arrangement that will allow you to use fuel pipe between injectors and mount the injectors just about anywhere.
Cheers
Simon _________________ Blown is always best! |
macBdog
Posted: Tue Sep 19, 2006 9:34 am Post subject: Re: Weber Alpha |
| simsport wrote: | | Weber make an injector cap and clip arrangement that will allow you to use fuel pipe between injectors and mount the injectors just about anywhere. |
Wow, what an awesome idea. So its like a fuel rail made of hose right? Where can you get this cap and clip system from? Where did you hear about it? _________________ 1979 931 with a 350 chev
1973 911E with EFI
hawkman
Posted: Tue Nov 14, 2006 6:48 am Post subject: |
i have a set of 360cc injectors out of a 93 3000GT VR-4, and a dsm fuel rail which i think i'll be using for my upgrade kit... anyone have any close up's of the parts that they used for the EFI kits? _________________ '81 924 n/a "The Baby" Modified!!!!!
'93 3000GT VR4 "Un-Touchable" |
Kenodog
steeny
Joined: 24 Nov 2005 Posts: 319 Location: Brisbane, Australia
Posted: Wed Nov 15, 2006 4:20 pm Post subject: |
gee, that almost makes me think that even I could handle an EFI changeover. must keep that in mind _________________ 1978 924 N/A
she's gone..... |
