Cheap supercharger
Goto page Previous  1, 2, 3, 4  Next
Guest
PostPosted: Wed May 22, 2002 4:43 am    Post subject: Reply with quote
ok here is an even better idea run a hose from your throttle body to your interior and just have a plug on it and when you want some boost plug in a CO2 cartridge more pressure than a tire no lag only downside is the bottles are so small.
or get a propane bottle and instead of filling it up with propain fill it with compressed air and just have a push valve inside the car and it will last for awhile plus hold about 100psi and just have an air regulator so you dont let 100 psi directly into your engine, only downside to fill up you would have to have an air compressor at home
teo
PostPosted: Wed May 22, 2002 4:48 am    Post subject: Reply with quote
so, are we going to invent NOS or stop here?
Guest
PostPosted: Wed May 22, 2002 4:54 am    Post subject: Reply with quote
NOS does way too much damage to an engine the sugestions i sudgested do what a turbo does but they arent constant
teo
PostPosted: Wed May 22, 2002 4:58 am    Post subject: Reply with quote
uhh, is this topic serious?
sorry, I missed that point
Guest
PostPosted: Wed May 22, 2002 5:01 am    Post subject: Reply with quote
hey you asked if you didnt want to know you shouldnt talk or ask
Cbass
Guest
PostPosted: Thu May 23, 2002 3:45 pm    Post subject: Reply with quote
Dear lord .
Now in my days as a crazy hotrodder, I have seen some incredible(completely lacking credibility) things, but this compressed air thing....
Why not mix a little pure oxygen into the tank? You'd get more power... How about hydrogen? It'll raise your octane rating
numbers
Guest
PostPosted: Fri May 24, 2002 8:27 am    Post subject: Reply with quote
teo, cbass, just collect the hot air from some of the blowhards on this post, and route that into your engine, and you will tear the tires off of your 924.
JvGinPDX
Guest
PostPosted: Fri May 24, 2002 10:26 am    Post subject: Reply with quote
Hey, run a hose from the manifold to the bottem of the drivers seat. Then go eat beans... Be careful of the suction though!!
Rick MacLaren
Guest
PostPosted: Sat May 25, 2002 12:19 am    Post subject: Reply with quote
The oxygen idea isn't bad. AN engine is just a pump, after all. Theoretically you COULD make an air car, running only on compressed air.
Guest
PostPosted: Sat May 25, 2002 2:08 am    Post subject: Reply with quote
yes you could run it on compressed air however it would have high revs but almost no torque
Cbass
Guest
PostPosted: Sat May 25, 2002 3:58 am    Post subject: Reply with quote
This was done in France a while ago, but I never found out how it worked. It was a non combustion engine apparently...
Anyways, what we need here is an underwater barbecue...
Rick MacLaren
Guest
PostPosted: Sat May 25, 2002 6:49 am    Post subject: Reply with quote
The French project is now a commercial success. They market the cars at around $15K USD and their speeds and torque aren't too shabby. I'll look for the link.
teo
PostPosted: Sat May 25, 2002 6:57 am    Post subject: Reply with quote
numbers,
routing that hot air into the engine will lead to early detonation, so I'll have to put a freezer on to the top of the car to cool that. Do you think it will hurt my drag coefficient? And if so, where can I find some aerodynamic ones?
Rick MacLaren
Guest
PostPosted: Sat May 25, 2002 7:52 am    Post subject: Reply with quote
Here goes:
http://www.zeropollution.com/zeropollution/
Here's one explaining the theory:
http://www.howstuffworks.com/air-car.htm
Here's one on a propane turbocharged 'Willys' Jeep.
http://www.truckworld.com/4x4-OffRoad/96-1957TurboWillys/1957TurboWillys.html
Cbass
Guest
PostPosted: Sat May 25, 2002 11:30 pm    Post subject: Reply with quote
Ah, they attempt to shoot down the theory of zero emissions with the fuel needed to compress the air... Same problem with hydrogen, most fuel companies will tell you.
However, if you use hydroelectric power, it's not an issue, you just have to build the dams, which we have a lot of in Canada. This gives us great potential as a major hydrogen producer.
Page 3 of 4
