Posted: Fri Oct 27, 2006 8:40 am Post subject: Hot Start Fix? |
Going through a few ideas for fixing my hot start problem and wondering why a fuel pressure regulator cannot be fitted the fuel return line.
It appears that the one built into my fuel dizzy doesn't work as everything else is fine.
I'm looking at this one.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&ih=001&item=110047148737&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
Comments anyone? _________________ Porsche 924 1984 (UK import) NA
Posted: Fri Oct 27, 2006 2:12 pm Post subject: |
I'd be setting the return line to 20-25psi and see what effect is has on the WUR and I wont be connecting a vaccum line at first. _________________ Porsche 924 1984 (UK import) NA
Posted: Fri Oct 27, 2006 5:07 pm Post subject: |
I don't see how it would help, Ozzie.
All the regulator would do is maintain the pressure between the regulator and the tank. It would do this by bleeding excess pressure back to ...er... the tank.
It could only do this if the back pressure was over 25 psi (say 30) anyway. Once this pressure drops to below 25 the output pressure from the regulator would drop too.
Besides, wouldn't the system pressure regulator close off the return line if there's no pressure from the pump?
I may have misinterpretted what you're trying to do. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Fri Oct 27, 2006 5:32 pm Post subject: |
I believe the pressure regulator in the fuel Dist is fubar and leaks back to tank after shutdown and parts are not available to repair.
AAV and WUR appear to work fine but I still have a hot start problem.
I plan to put a pressure regulator in the fuel return line that will keep the pressure at a minimum of 25psi (about 1.7bar).
This will keep the system from the pump through to the regulator at 25 psi and prevent vapor lock (after shutdown)
When the motor is running the fuel dissy will operate as normal. (in theory) _________________ Porsche 924 1984 (UK import) NA
Posted: Fri Oct 27, 2006 6:03 pm Post subject: |
| Ozzie wrote: | | This will keep the system from the pump through to the regulator at 25 psi and prevent vapor lock (after shutdown) |
This is the job of the accumulator.
After I replaced mine (because of a leak), my hot start problem got less of a problem (didn't go away completely). I suspect I, too, have a slightly leaky pressure regulator. PET shows the O-rings as replaceable items; I shall put that to the test on my next visit to the local VW dealer.
I don't want to piss on your bonfire, Ozzie, but I still don't think your idea of a regulator in the return line will work. If I understand what you're proposing, the regulator would go in the return line from the fuel dist regulator and the tank (Yes?). Even if the fuel pressure reg was leaking, it's doubtful that the pressure in the return line would reach 25 psi. (Remember that the regulator should shut the return line off immediately after engine shutdown - to preserve the pressure at the business end.) _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Fri Oct 27, 2006 6:13 pm Post subject: |
If you're sure that your fuel dist regulator is completely U/S, what you can do is put your new regulator in the line between the filter and the dist, and set it to 70 psi, effectively replacing the function of the fuel dist reg. Block off the return port from the fuel dist (not sure how to do this) and feed your return line from the new regulator.
Should work in theory, but I can't picture the circuit in enough detail to be sure if it will work in practice. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Fri Oct 27, 2006 10:46 pm Post subject: |
The fuel pressure regulator in the dist has two functions.
1 maintain system pressure when running at 4.5 to 5.2 bar and drains excess to tank.
2 maintain pressure when shutdown at 1.5 to 1.7 bar by shutting off the drain.
It does the 1st one just fine.
After shutdown any pressure above 1.7 usually drains to tank and then it should shut off. This it doesn't do.
The accumulator is like a balloon which pressurises when the pump is running. When the pump shuts down the accumulator will maintain pressure in the lines if there is no leaks. Mine is leaking past the pressure regulator.
If you look at page 73 of the Haynes and look at item 13 in the picture you' get an idea of the CIS. I am thinking of putting a regulator between 13 and 15.
From this diagram if you blocked off the fuel return line you would get pressures well above 25psi. _________________ Porsche 924 1984 (UK import) NA
Posted: Fri Oct 27, 2006 11:00 pm Post subject: |
Another option I was looking at was an electric shutoff solenoid that would shutoff with the fuel pump. _________________ Porsche 924 1984 (UK import) NA
Posted: Fri Oct 27, 2006 11:42 pm Post subject: |
That would work much better. If fact, because it's effectively instant, it might keep the pressure up well above 1.7 bar. Again, it all depends on how good your accumulator is. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Sat Oct 28, 2006 1:57 am Post subject: |
Why not just replace the o-ring seals in the fuel dist's pressure regulator? Should be one, or in the case of later versions with the WUR return check valve, two o-rings as in this diagram - http://pg.photos.yahoo.com/ph/smoothies931pics/detail?.dir=341f&.dnm=3e72.jpg&.src=ph _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Sat Oct 28, 2006 3:18 am Post subject: |
| Smoothie wrote: | | Why not just replace the o-ring seals in the fuel dist's pressure regulator? |
Part numbers 911 110 936 00 and 900 123 033 20 _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Sat Oct 28, 2006 7:24 am Post subject: |
In Smoothies pic it shows the return from the WUR going throught the regulator.
Mine does not do that. Maybe Lambda?
No kit available for the NA.
The 'o' ring option would be cheaper. _________________ Porsche 924 1984 (UK import) NA
Posted: Sat Oct 28, 2006 9:52 am Post subject: |
Decided to pull out the regulator and check the seal etc.
This is what I found
No shims and the seal is hard so I'll see about getting these from the dealer on Monday.
Pelican has them but I'll have to import from the USA.
Might solve a few problems. _________________ Porsche 924 1984 (UK import) NA
Posted: Sat Oct 28, 2006 10:04 am Post subject: |
New info in next post... _________________ White 87 924S "Ghost"
