924 - 931. Suspension question.
PostPosted: Sat Oct 14, 2006 6:52 pm    Post subject: 924 - 931. Suspension question. Reply with quote
Hi.
I have a question for you guys. What is actually the difference in suspension components on those two cars. I have checked on both cars but i cant spot anything that differ.
Sway bars are the same, 14mm rear, and i think 23 at the front. I think its the same size torsion bars. And i did a quick measure on the front springs and it seemes that those are the samte to. Do the have different dampers ?
PostPosted: Sat Oct 14, 2006 10:24 pm    Post subject: Reply with quote
The options were pretty much the same - perhaps the 931 (later years, anyway) had a more advanced base suspension?
Actually no, as I think about it; while the 81-82 cars had the disc brakes standard, they didn't necessarily have a rear swaybar. My '82 doesn't have a rear bar.
PostPosted: Mon Oct 16, 2006 2:23 am    Post subject: Reply with quote
The front springs should be different to accomadate the different weight engines - look for color code stripes painted onto them. The color and number of stripes indicate what they are.
Rear torsion bar is 23.5mm for both 924NA and 931 except for 924NA's that didn't have a factory-installed rear stabilizer bar - those got a 22mm torsion bar. All 931's regardless of whether they had a factory rear stabilizer, got the 23.5mm tb's.
My '82 931 didn't come with a rear stabilizer bar either. I eventually upgraded to 22mm rear and 28mm front as the parts came on sale. (Because, of course, as I've mentioned - I'm a cheap bastard.)
PostPosted: Mon Oct 16, 2006 2:51 pm    Post subject: Reply with quote
As far as I know, all Turbos were lowered and had "better" shock absorbers, as well as the above mentioned differences. They also all came with 15-inch wheels (again, as far as I know).
RoW cars, certainly those delivered to Australia, appear to have come "fully loaded". As an example, so far I've been able to gather, all Australian cars came with disc brakes all 'round. It's very likely they all came with optional suspension parts mentioned above.
Porsche are not the only manufacturers to this. Nearly all others do this. For example, when the Audi TT was released in Australia, initially only the quattro turbo was available, even though I think a fwd, non-turbo (and possibly other variations?) was available elsewhere around the world.
Different markets around the world often get different spec. levels of a given model to suit the local market.
PostPosted: Tue Oct 17, 2006 1:53 am    Post subject: Reply with quote
Steering ratios also differed depending on year and market. -And brake boosters...
Can't remember where's the link to that tech specs pdf..
scotchw
PostPosted: Thu Oct 19, 2006 8:41 am    Post subject: Reply with quote
Cedric - as you are in Sweden you'll have a Euro car. These had many upgrades compared to the NA cars. But the US 931's only got partial upgrades because the emission regulations restricted the power output (so they didn't need all the brake/suspension upgrades!)
So you will definitely have uprated front springs (I confirmed this by swapping my front springs for aftermarket 924 lowering springs.... but they were way too soft & lowered the car too much as they weren't meant for a turbo - I had to swap back to my original springs!), & the rear anti-roll (sway) bar, discs all round & 15" wheels.
'82MY 924 Turbo Euro RHD
John Brown
PostPosted: Thu Oct 19, 2006 11:11 pm    Post subject: Reply with quote
IIRC, the standard front springs na are somewhere around 140lb and the 931 160lb. Not a big difference. On this side of the pond the most common 'lowering springs' were either 200 or 220 or 250. FWIW, it has been my opinion that the most you could go without ruining the balance - well, I take that back - understeer starts with the 200 unless the back is done also. The most you can go without ruining the balance is the factory springs.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
NEMESIS
PostPosted: Thu Oct 19, 2006 11:54 pm    Post subject: Reply with quote
scotchw I'd like some clarification as to the specific "partial" upgrades you are speaking to. So can you tell me what the ROW cars have over my 5 lug, 4 wheel vented discs, 160 lbs springs, stock (I forget dia.) torsion bars, 23 front and 14 rear sway bars, Boge shocks/struts, and 16" wheels?
I think Khal has you ROW guys thinking you have completely different cars just based on a bit more boost and better looking bumpers.
82' 931 Platinum <--GTS in progress
PostPosted: Fri Oct 20, 2006 2:37 am    Post subject: Reply with quote
No, no, I don't mean that.
But, for example, you could get a Yank Turbo with drum rear brakes. I've never seen an RoW car with that. I've never seen one without a snailshell, either. That's just examples. It makes me suspect there may be other things as well.
I'm not stating the particular spec. of every Yank or RoW car. Per the above, I guess I just wanted to point out that there seems to be more variation in Yank spec's compared to RoW spec's.
PostPosted: Fri Oct 20, 2006 5:20 am    Post subject: Reply with quote
hm, i´ve heard about front springs being different. But the diameter was the same. Must be further investigated. I will swap and take both cars struts apart this winter so i can do the measuring.
All cars here in sweden also seems to be "fully loaded". I have never seen a turbo with drums. And they all seem to have all the unnecessery electric stuff. They also have, what i have seen a little bit more of sound insulation. I found insulation plates that i´ve never seen in my n/a.
Just so you know what i´m doing over here....I´m restoring and making a 931 more track worthy, have the engine totally apart. Lots of work to do.
some pics in this thread: http://www.944sverige.com/forum/viewtopic.php?t=7510&postdays=0&postorder=asc&start=0
I´ll start with a more streety setup. 250# at the front, 25.5mm at the rear. Maybe ill try the 30/19 sway bars. But I´m afraid that i´ll get to much inner weel spinn at corner exit.....
ooop. this had nothing to do with the topic....
scotchw
PostPosted: Fri Oct 20, 2006 9:53 am    Post subject: Reply with quote
Hey nemesis - you got yourself a "sport group" car! This was an option pack on the US cars. It provided:
14mm rear sway
22.4:1 ratio rack
16" forged alloys ("flat-plate/slots"?)
205/55 tyres
All vented disc brakes (11.1" dia instead of 10.1)
However, the 160lb springs were fitted to all turbos.
US cars did have a smaller turbo giving 143bhp instead of RoW/Euro 170bhp... but gearing was changed to compensate: US cars had lower 1st gear & other 4 higher + final drive of 4.71 (Euro was 4.125 final drive). This means (due to smaller turbo spinning up faster & lower gearing) that US car is faster to 80mph than a Euro, but loses 10-12mph in top speed.
All US cars had a cat & O2 sensor (+ other emission controls varying by state), but Euro's had none of this. "Standard" US turbos had the regular 924NA disc/drum brake setup with a 7" brake servo/booster (whereas the all-disc setup used a 9" booster).
NEMESIS
PostPosted: Fri Oct 20, 2006 11:27 pm    Post subject: Reply with quote
14mm rear sway
22.4:1 ratio rack
205/55 tyres
Cool, I thought all 5 lug 931's were equipped the same.
Is "sport group" the same as the M471 option or something more/less? I thought package included Koni shocks/struts or something?
...and Khal I was just having a go at ya mate, I like my discussions spicey!
scotchw
PostPosted: Sun Oct 22, 2006 7:46 am    Post subject: Reply with quote
Yep - M471 is the 'sport group' option. But 474 is the standard Porsche code for 'sport suspension' (shocks) - so uprated shocks (Koni/Bilstein)should be accompanied by this code.
Trouble is Porsche were a bit inconsistent with codings on each car's build sticker. So you could have had uprated shocks at the factory, but if you also had 'sport group' they might have only put M471 on the build sticker....(instead of both 471 & 474)
