porsche.racer
Joined: 20 Jun 2006 Posts: 106 Location: california, US
Posted: Thu Oct 12, 2006 3:51 am Post subject: is over boost bad?? even if just for a second |
I have a boost controller and was trying to set it up and ended up OVER boosting for a second - then the waste gated or bosst controlerer dumbed all my boost. But, seemed ok after? Could this have done damage. I boosted to about well... my gauge goes to 15psi and I went by it some to 17-18-19 maybe not sure where - only for a second?? Thanks _________________ 1987 911 3.6L Carrera with LSD
1986 944 Turbo (Track)
1972 911 3.0L Turbo Look
1988 944
100's of good used parts MUST GO
Check me out on EBAY I.D. porsche.racer |
Posted: Thu Oct 12, 2006 3:59 am Post subject: |
You are probably OK, but if you are going to continue "experimenting," you should bench test your boost controller switch, which should kill the fuel pump when actual intake pressure exceeds 15 PSI. Sounds like you need a functioning one! _________________ Toofah King Bad
Posted: Thu Oct 12, 2006 7:10 am Post subject: |
You better fix that boost-controller.
If you want to experiement with boost, why not by a knock-link knock detector ? It doesnt cost that mutch. And can save you a lot of money.. _________________ 1980 924 Turbo
Kenodog
Posted: Thu Oct 12, 2006 1:30 pm Post subject: |
When you get detonation you'll know it. _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
