newbie w/snail shell question
lenney
PostPosted: Fri Oct 06, 2006 7:55 am    Post subject: newbie w/snail shell question Reply with quote
hi all
i've been lurking for sometime and finally joined! i bought my wife a 79 924 with some problem that i resolved by searching. the main problem i am having now is 1-2 gear clash when cold and it's reduced when i've driven some miles and everythings warmed up. any ideas?. also, my shift coupler is half broken! is there some easy way to replace this? (i do have a hole under the back seat). thanks
lenney
PostPosted: Fri Oct 06, 2006 9:54 am    Post subject: Reply with quote
there is nothing really that can be done for the 1-2 shift,
with the shifter linkage, what is worn is two plastic bushings, you have to remove the tranny to be able to remove the shift rod to be able to replace the bushings.
while you are at it you will need to replace the ball cup bushing as well.
3 928s,
PostPosted: Fri Oct 06, 2006 10:00 am    Post subject: Reply with quote
Do you mean without rebuilding the gearbox? It sounds like a syncho problem to me... the syncho's can be replaced, right?
PostPosted: Fri Oct 06, 2006 10:30 am    Post subject: Reply with quote
Only if you can find the parts, mine was in the shop for a year and cost over $1500 when I picked it up.
isuras2
PostPosted: Fri Oct 06, 2006 10:35 am    Post subject: Reply with quote
I have the audi tranny and had some 1-2 grinding. I changed the fluid from whatever the PO had to Amsoil synthetic (I think it was 75W-90). That seemed to help, but I still have to double clutch between 1-2. At first it was a little wierd, but now it is second nature.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
Sebring79
PostPosted: Fri Oct 06, 2006 1:44 pm    Post subject: Reply with quote
Rob's right, synthetic can make a difference. I found it especially true on the snailshell tranny. I haven't ever had the grinding problem on my car but switching to Redline (I think it was Redline, it was a while ago) made shifting much smoother in general.
And not to change the subject, but Paul... Do you have any pictures of your car? I just noticed that huge flare on the rear.
PostPosted: Fri Oct 06, 2006 4:04 pm    Post subject: Reply with quote
Yeah, I just put in the multi weight Royal P, and my trans is much happier. . .of course, it was stored for quite a while. . .
rasta
PostPosted: Fri Oct 06, 2006 10:03 pm    Post subject: Reply with quote
EBS Racing can help sourcing synchros, though it may be tricky to ID the correct one for 1st gear, to do the rebuild.
I highly recommend considering having it rebuilt before the dog teeth on the actual gears are damaged; if the latter happens, you're looking at many hundreds if not thousands for each part alone, instead of $100-120 per synchro.
Vince Ponz
PostPosted: Fri Oct 06, 2006 10:59 pm    Post subject: Reply with quote
Fix coupler first. It is cheaper and then go further.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
PostPosted: Sat Oct 07, 2006 5:41 am    Post subject: Reply with quote
Actually Khal I meant entirely, as it mainly happens while cold. you just have to learn how to shift nicely and rev match as much as is possible or skip second while cold.
also this is for the 924 NA snailshell, for which I imagine the syncros will be even harder to find than the 931 snailshell.
3 928s,
lenney
PostPosted: Sat Oct 07, 2006 7:41 am    Post subject: Reply with quote
thanks for the replies! i'll try the synth oil first. on my shift coupler it's not the bushings the rear "horseshoe" parts is broken and the po put a bolt through it!. i do have mixed feelings about this car sort of a love hate relationship! it is fun to drive around town but i dont trust it yet on long trips!
lenney
1979 924 5-speed
1971 oldsmobile 442 455 cid
1991 rx7 400 sbc
1987 chevette g200 isuzu (cloned into a gemini)
2 jeep xj's
Vince Ponz
PostPosted: Sat Oct 07, 2006 11:16 am    Post subject: Reply with quote
Fix the bushings first. If broken it will not go all the way to one side and therefore the grinding.
Amen.
79 931 Euro stock
88 924S SE
87 911 Targa stock
PostPosted: Sat Oct 07, 2006 1:30 pm    Post subject: Reply with quote
Amen.
