Joined: 29 Jul 2001 Posts: 9129 Location: Royal Oak, MI, USA
Posted: Thu Aug 03, 2006 10:05 pm Post subject: 931 expansion tank (rad) cap - updated P/N |
An FYI, I found a replacement for my coolant expansion tank cap last night (what some might incorrectly call a radiator cap). This is the screw-on type, not the push in and 1/4 turn style used on the 2.0L NA and the 2.5L cars, as common on many VW's.
The original P/N is 171.121.321. Replacement part listed in the parts manual is 171.121.321D.
The part I got that looks the same, except it's blue, is 443.121.321. Again, obviously, as you'd expect, it appears to be a pretty standard VW part...
Hopefully now my system will hold pressure and stop dumping coolant all over the place once the temp gets above the 3/4 mark... very embarrasing at the dealer... _________________ Vaughan Scott
scotchw
Joined: 14 Aug 2005 Posts: 30 Location: Basingstoke, UK
Posted: Tue Oct 03, 2006 10:25 am Post subject: |
I just replaced my old expansion tank & cap with Porsche-supplied parts (couldn't even see coolant through the 'browned' old plastic!). Was surprised to see the blue cap too:
Actually the cap has a 996.106.447.01 no. & a different pressure relief design underneath.
One thing on exp tank too - look carefully in photo & you'll see that main outlet port on new tank is different length & angle than original
Same part no. as original too - strange. Had to adjust hose to make it fit. _________________ '82MY 924 Turbo Euro RHD |
Posted: Tue Oct 03, 2006 9:54 pm Post subject: |
I'll bet that makes the engine compartment look 10 times better! _________________ Vaughan Scott
scotchw
Posted: Wed Oct 04, 2006 3:29 am Post subject: |
It did until I went out for my maiden voyage after fitting it!
I also replaced a couple of w/pump hoses (the tstat one had been weeping for some time I suspect):
Now I've realised (looking at other threads) that my head gasket must have gone - my new expansion tank was blown up like a balloon after a 30 mile cruise on the highway
Now that my cooling system is airtight its highlighted the 'real' problem behind my string of hose failures  _________________ '82MY 924 Turbo Euro RHD |
