I need a soundproof
Carlo
PostPosted: Thu Sep 28, 2006 6:33 am    Post subject: I need a soundproof Reply with quote
Hi!
I need this soundproof:
As spare parts in Porsche is terminated.
There's someone that know where i can find it (original or replacement)?
Tnx!
JB 924
PostPosted: Thu Sep 28, 2006 7:32 am    Post subject: Reply with quote
You should be able to buy soundproofing material. Just go to your automotive parts place and ask them where you could get some. I doubt anyone makes exact replacements and it surely wouldn't be worth buying from Porsche.
Hope this helps,
JB
Carlo
PostPosted: Thu Sep 28, 2006 6:46 pm    Post subject: Reply with quote
thank you, in effects i already found tha material adaptable for the substitution of the original soundproof.. (http://www.mcmantom.com/prodotti/trattamenti_acustici/06.40.01/)
but I wanted to know if I could find it equal to original item...
however... the same one goes well
PostPosted: Thu Sep 28, 2006 9:51 pm    Post subject: Reply with quote
Consider using insulation with foil backing to reduce the amount of heat transmitted to the inside; I found my first 924 had the problem where a lot of heat came through the firewall. When re-doing the interior of my 82 931 I put new insulation with the foil backing (bought from the hardware store, used for insulating water heaters and the like) underneath the carpet. It's also nice in that you can find thinner pieces for use under the pedals.
Worked great, now the inside of the car doesn't get heated up in the summer.
Now I have to do the same to my racecar; nearly burn my right foot on the center tunnel while standing on the gas!!!
dan476
PostPosted: Fri Sep 29, 2006 2:07 am    Post subject: Reply with quote
why not use Dynamat? or something along those lines?
Carlo
PostPosted: Fri Sep 29, 2006 6:43 pm    Post subject: Reply with quote
no dynamat, because i want to maintain the car most possible as it was in origin..
the material of the product that I have found is not equal to original them but it is approached to it.
thanks anyway
dan476
PostPosted: Fri Sep 29, 2006 8:39 pm    Post subject: Reply with quote
i do not see the difference. it will be covered uder the carpet, it does the job it is supposed to do and it is light. But i guess to each their own.
