Annoying oil leak
aweizd
PostPosted: Fri Sep 22, 2006 4:51 am    Post subject: Annoying oil leak Reply with quote
Hi guys,
I need some advice on this.
I have oil leaking from my 924S engine, well... actually it's a 944 engine.
The oil seems to come out from underneath the power steering pump mounting arm, which is located to the front of the oil pressure sender. I had no chance to take it apart and what the problem is, but I'm planning on doing that tomorrow or over the weekend.
Do any of you have an idea where the leak might be originating?
If I want to remove the power steering pump mount, do i have to remove the timing/ballance belts first? I'm asking cause it's places really close to those belt.
Anyways it'd be great if I could get some advice on this.
Thx in advance[/img]
1987 Porsche 924 S - Munich, Germany
PostPosted: Fri Sep 22, 2006 7:21 am    Post subject: Reply with quote
Welcome!
The PS pumps have an O ring the seals the halves of the case. It's been know to leak. Are you losing PS fluid?
You do not have to touch the timing belt covers to remove the PS pump.
aweizd
PostPosted: Fri Sep 22, 2006 9:22 am    Post subject: Reply with quote
hi,
it's just motor oil leaking from underneath the PS pump mount. The PS pump is fine.
PostPosted: Fri Sep 22, 2006 10:12 pm    Post subject: Reply with quote
Either it's one or more front seals on the engine, or possibly the oil pressure sender. As I recall, there isn't anything under the mount that can cause the leak?
To get the pump off, you only need to remove the PS belt, but to get the mount off, you need to remove all belts plus the back half of the timing belt cover.
Mine may still have a lingering leak in that area. Hard to say right now, as the replacement oil pan gasket I put in blew out (must be my fault), and so it's pissing oil badly out the side of the engine.
You may be looking at a front engine reseal job; put in new timing and BS belts while you're at it.
aweizd
PostPosted: Sat Sep 23, 2006 2:08 am    Post subject: Reply with quote
Hi and thanks for your replies,
I took a look at it today, and the leak seems to be somewhere between the water pump and the oil radiator cover. Does oil travel through the water pump? If so, than that's probably it. I don't have any coolant in my oil or vice versa, so it's probably not that big a deal. I don't think I'll get around to fixing that any time soon. I still have around 40000km to go on these belts so I'll have to live with the leak for a while... unless (knock on wood) it gets really bad.
Thanks again
Greetz
dgz924s
PostPosted: Sat Sep 23, 2006 11:30 pm    Post subject: Reply with quote
The S shaped hose with the spiral plastic covering is a known leaker. There is an update fitting that also is a issue. This hose runs from the PS tank to the pump. This hose is in an area of intense heat and it breaks down rather EZ. Drain the PS tank and degrease all the area then run w/o PS and see if the leak ceases. Can't leak w/o PS fluid. If a leak appears then from the area described I would suggest the cam tower gasket then the oil cooler housing and oil sender.
Dal
Dal Glassinger
3d914
PostPosted: Fri Oct 06, 2006 1:40 pm    Post subject: Reply with quote
aweizd,
Here's a no-brainer you can check. IN that same area is the oil filter. If you haven't already - check to make sure its snug. The PO for my car had one of these oil-lube-tuneup places do his oil change and they didn't get the filter tight enough - slow leak!
Enjoy!
Gerard
74-914 2.0L Ravenna Green
87-924S 2.5L Alpine White
