cross reference number for Fuel Filter (rear)
Blas
PostPosted: Tue Sep 12, 2006 11:53 pm    Post subject: cross reference number for Fuel Filter (rear) Reply with quote
Anyone have a cross reference number for the in-line fuel filter between the tank and the pump at the rear of a 1979-924?
The Porsche # is 477-209-233 but I'm sure Bosch or Purolator has something....
Thanks
PostPosted: Wed Sep 13, 2006 12:36 am    Post subject: Reply with quote
The little thing? It's not actually a filter, as I recall, but a baffle to cut down noise.
Blas
PostPosted: Wed Sep 13, 2006 1:58 am    Post subject: Reply with quote
In on the side - out on the top - PET catalog calls it a filter.....odd...
Part #28 in the PET catalog.......
D Hook
PostPosted: Wed Sep 13, 2006 9:51 am    Post subject: Reply with quote
I thought that was the accumulator that cut down the noise by smoothing out the fuel flow and kept pressure in the lines after shut down.
Anywho, I've got a filter back there but I believe it's just a generic in-line filter. Go to Napa or favorite parts store and match it up by dimensions, maybe?
I would guess as long as you don't put something tiny on there made for a motorcycle or a lawnmower, you'd be okay.
*EDIT* I just checked my parts book and it doesn't show it so I'm not sure all models came with it or if my PO added it. It's mounted in the hose between the in-tank pump and the fuel pump, IIRC.
'80 924 n/a SOLD
Blas
PostPosted: Wed Sep 13, 2006 9:54 am    Post subject: Reply with quote
The rear filter says VDO on it but the numbers can not be read...Anyone got an old one laying around for the numbers?
Thanks
D Hook
PostPosted: Wed Sep 13, 2006 9:56 am    Post subject: Reply with quote
Thanks
If I get a chance, I'll try to get out and check tonight for a number/brand.
'80 924 n/a SOLD
Stampedetrail
PostPosted: Thu Sep 14, 2006 2:37 pm    Post subject: Reply with quote
My car has 2 accumulators... not sure why. One is brand new as of July.
1977.5 924 "Martini" head / New Old Stock rebuild
1985.5 944 Why? Because I can.
PostPosted: Thu Sep 14, 2006 5:01 pm    Post subject: Reply with quote
Early cars had 2 accumulators of 20cc each.
Later had one 40cc.
Blas
PostPosted: Fri Sep 15, 2006 2:01 am    Post subject: Reply with quote
May have found a replacement rear fuel filter:
Purolator #F29128 - $3.50
I just need to verify the hose ID sizes....
Unless anyone has the hose diameter information handy...????
I'll post back my findings....after a fit-up....
mhariush
PostPosted: Mon Mar 11, 2024 11:28 am    Post subject: Reply with quote
Very old thread i know, but these are old cars
I'm in the process or replacing this myself... What did you end up doing here?
78 924, 87 944S, 89 944 Turbo, 08 Cayenne
