Charlane
Joined: 25 Jul 2005 Posts: 50 Location: San Antonio, TX
Posted: Fri Sep 01, 2006 3:39 pm Post subject: Where To Buy An Oil Pump? |
Just when I thought I had everything worked out and installed a bunch of new ground wires for solid grounding, the oil pump gives out. My local dealership quoted me $415 not to include shipping. Does anyone have a place to go where the price tag isn't so painful? I'm on short change and this is now my daily driver. Thanks. _________________ Electra is Here......
One 1980 924 Turbo
One 1990 KZ1000P (CHPS) Motorcycle
One 1984 244 Turbo Volvo (B21FT) (I installed this engine myself)
One 1977 240D Mercedes Benz
One 1970 Chevy Impala |
Posted: Fri Sep 01, 2006 5:43 pm Post subject: |
What's up with the oil pump? Are you sure of your diagnosis?
It's a very simple unit and, unless something actually breaks off, I don't see that there's much to go wrong. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Sat Sep 02, 2006 12:08 am Post subject: |
Has one checked to make sure the pressure relief valve is not stuck? _________________ White 87 924S "Ghost"
-nick
Posted: Sat Sep 02, 2006 2:47 am Post subject: |
I've got an extra one lying around if you need it. Was giving excellent oil pressure before I pulled it off. Send me a PM _________________ 1980 931S
1991 964 C4 Cabriolet |
OutOfTheBox
Posted: Sat Sep 02, 2006 6:01 am Post subject: |
| Quote: | | Was giving excellent oil pressure |
with or without Coca-Cola or VIM  |
Charlane
Posted: Sun Sep 03, 2006 2:26 am Post subject: |
Hi Paul. You might be onto something there because the oil seal is leaking oil. I could see if the oil pressure backed up how this would affect it. I need to look into this more. Do you have any more information? I'm getting ready to take off the pump on Wednesday of next week because I'm working on location.
Thanks in advance. _________________ Electra is Here......
One 1980 924 Turbo
Posted: Sun Sep 03, 2006 5:22 am Post subject: |
Are you replacing it because of the leak or due to the lack of oil pressure?
The pressure relief valve is very easy to check, it's part of the oil pump. All you have to do is to remove the big cover (looks like a large nut). Behind it you will find a spring and a small piston. Makes sure the piston moves freely. _________________ White 87 924S "Ghost"
Charlane
Posted: Tue Sep 05, 2006 12:37 am Post subject: |
Hi Paul. I thought that the oil pressure switch shut off the electrical start if there was a problem. My car starts. It just runs very rough after a while and now I understand why I'm getting flat lobes on my camshaft. There is just no oil reaching the top. This could be by blockage or because the oil pump is not functioning. I was reading in my Haynes where the oil pan should be removed and cleaned every 22K miles because it might block the oil feed tube, which makes sense to me. _________________ Electra is Here......
One 1980 924 Turbo
Posted: Tue Sep 05, 2006 1:04 am Post subject: |
No, most likely it's that the plastic cam oiler tube elbow, a $5 part, has failed, is leaking oil everywhere in the cam area, and not providing oil to the cam.
Parts you'll need to fix this:
cam cover gasket set - new
cam oiler tube elbow - new
camshaft - good used, or regrind - hey, time to upgrade!
lifters - good used, as needed, won't know how many you need if any till you get the old cam out
I recommend EBS Racing for the new parts. Should be able to get a replacement cam from someone here on the board, unless your budget allows an upgraded regrind. Same for lifters.
New oil pumps are like $400 or so. If your oil pump was bad, the whole engine would be trashed from top to bottom, not just the cam. Your oil pressure likely also reads low, since the sender is up there by the cam.
Sorry for the bad news, but on the bright side, this should be cheaper and easier than putting in a new oil pump. _________________ Vaughan Scott
Charlane
Posted: Tue Sep 05, 2006 1:27 am Post subject: |
It's not that bad of news since I already knew that I had to replace the camshaft but I sure am glad that you wrote about that elbow. I read that somewhere before and it sure did get my interest and moreso when my car decided to put it on my table. Can I get that number to EBS from you? Where does that elbow sit btw? I think I'm going to get another oil pump anyway just to be safe.
One other thing. I read in my Haynes where the camshaft could be one of four choices because of timing differences in the North Americas (this must be relative to elevation I think). I have another camshaft I bought on the fly and I know it's for a 924 of the same year as mine but reading this makes me realize I need to find out for sure what this is all about. Do you have any info on the camshaft differences in timing for a given 924? This camshaft might fit but then some other nasty problem springs up and I don't want that to happen, no sir.
One 1980 924 Turbo
D Hook
Posted: Tue Sep 05, 2006 2:11 am Post subject: |
This is for your 931 (aka 924 turbo) correct? _________________ '80 924 n/a SOLD |
Charlane
Posted: Tue Sep 05, 2006 2:26 am Post subject: |
Damn, I need to pm Nick on that. He has a 931 I believe. I need to clarify the difference between 924 and 931. I do have what I believe to be the K-Jetronics setup (air flow diaphram/vacuum plate housing attached to the airbox/also known as a 'thingie') on mine but that shouldn't change the model number. What is the difference between the 931 and 924? Does it have anything to do with the crankcase or is this strictly dealership modification for the vacuum/exhaust system? I would have to determine where my booster would be if what I have is even that. I'm familiar with Swedish turbo systems but not Porsche....yet. _________________ Electra is Here......
One 1980 924 Turbo
Posted: Tue Sep 05, 2006 5:01 pm Post subject: |
I'll try to keep this simple
Open your bonnet (hood).
Look inside.
If the 'thingie' is on your right-hand side, your car is NA (normally aspirated,at least originally) aka a straight 924.
If the 'thingie' is on your left, it's a turbo, otherwise known as a 931. You won't be able to see the turbo unit beacause it's tucked under the engine, but you will be able to see the induction pipe coming up from your left and over the top of the cam cover. It will have 'turbo' written on it. That's a bit of a clue. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
