isuras2
Posted: Thu Aug 17, 2006 4:56 am Post subject: Valve Cover |
Is it possible to remove the valve cover with just removing the bolts? Or does the dizzy need to be removed, adjusted to allow more room. Mine seems to be caught on the dizzy vacuum advance part.
Thanks, _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
StienbargerR
Posted: Thu Aug 17, 2006 11:50 am Post subject: |
Can you pull the vacuum tubes?
Ryan _________________ 1978 924 NA
isuras2
Posted: Thu Aug 17, 2006 12:40 pm Post subject: |
The tubes are not the problem, where they connect on the dizzy is the problem. _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
leadfoot
Posted: Thu Aug 17, 2006 12:51 pm Post subject: |
Yes you do not need to remove the dissy...
but in you case you may need to rotate it, in which case you will need to reset you timing upon refitting of the cover, it sounds like you sparks plug wires may be in the wrong holes in the dissy cap, not out of order though...
carbon fiber GT mish mash
Posted: Thu Aug 17, 2006 5:19 pm Post subject: |
Like leadfoot says you can do it without removing the dizzy, but I reckon it's easier if you do. Re-timing the ignition is no hassle and is a regular job anyway. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
isuras2
Posted: Thu Aug 17, 2006 9:41 pm Post subject: |
Thanks guys. I'll see what I can do. _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
Posted: Thu Aug 17, 2006 10:19 pm Post subject: |
I've never had to remove or even pivot the distributor to pull the valve cover - I wonder if your distributor is clocked incorrectly on the head? You know, the way the distributor housing can be bolted on in two positions, resulting in two different angles... one more upright and closer to the hood, the other more laid-over... _________________ Vaughan Scott
isuras2
Posted: Fri Aug 18, 2006 1:52 am Post subject: |
Hmm...I'll have to look into that. _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
pmohr Guest
Posted: Fri Aug 18, 2006 9:42 am Post subject: |
| 924RACR wrote: | | I've never had to remove or even pivot the distributor to pull the valve cover - I wonder if your distributor is clocked incorrectly on the head? You know, the way the distributor housing can be bolted on in two positions, resulting in two different angles... one more upright and closer to the hood, the other more laid-over... |
Which way is more...'correct'? |
Posted: Fri Aug 18, 2006 10:24 am Post subject: |
more laid over,
if it is in the more upright position it will hit the hood and decrease the life. _________________ 3 928s, |
