Desolation
Posted: Thu Aug 17, 2006 8:01 am Post subject: High revs and white smoke |
I finally started it today and when I did i looked at the tach and its running at 3k rpm and is really loud, I adjusted the intake and that didnt help at all, then I looked at the back and it just comes out constant white smoke puff puff puff Anyone have any ideas _________________ 1977 924 - sold
1989 Mustang
My MySpace ^_^ |
J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Thu Aug 17, 2006 8:37 am Post subject: |
sorry i cant remember the history of your car. does the white smoke smell like coolant? have you checked the oil for milkshake? you might have a blown head gasket!!
hope im wrong! _________________ '86 944 |
Desolation
Posted: Thu Aug 17, 2006 8:57 am Post subject: |
Heh sorry but I have no idea what milkshake is... and I dunno what coolant would smell like, what kinda coolant? like antifreeze? _________________ 1977 924 - sold
1989 Mustang
My MySpace ^_^ |
Desolation
Posted: Thu Aug 17, 2006 9:26 am Post subject: |
I took off the cap and also the dipstick it all looks like good oil to me.. _________________ 1977 924 - sold
1989 Mustang
My MySpace ^_^ |
Posted: Thu Aug 17, 2006 9:58 am Post subject: |
If its glycol based coolant then it will likely smell kind of sweet
Are you losing coolant?
Does the car overheat?
Was it ever overheated?
How old is the gasoline?
Vacuum leaks?
Does the smoke go away when the motor is revved up?
Does it go away when the engine warms up?
Good luck,
Stefan |
jaxrepo
Joined: 04 Jan 2004 Posts: 162 Location: Jacksonville, FL
Posted: Thu Aug 17, 2006 10:28 am Post subject: |
White smoke is water reaching the exhaust manifold. Probably have condensation in the gas tank if the car has been sitting for a while. Try STP super gas treatment - it will disolve the water in the gas & the smoke should go away. God luck. _________________ 83/86 944 Parts cars (2)
78 924 Parts car
84 944
88 924S Parts car
Web site at www.jaxrepo.com - 944/924 parts. |
Posted: Thu Aug 17, 2006 11:02 am Post subject: |
do a compression test, sounds like high water/gas mix, or blown head gasket. _________________ 3 928s, |
Desolation
Posted: Thu Aug 17, 2006 12:35 pm Post subject: |
Well my dad came over and fixed it, he just had to adjust the idle on it and it seemed to work I was doing the wrong screw, and we both took turns driving it around the block Finally I know it works at least, no smoke either after that, guess it was just from sittin.. _________________ 1977 924 - sold
1989 Mustang
My MySpace ^_^ |
Posted: Thu Aug 17, 2006 5:40 pm Post subject: |
Condensation will build up in the pipe and steam will come out for a while until it all boils off.
If after that you have nothing then its probably ok.
My daughters car is the same while I'm working on it and start it every 2 weeks or so. (offered her a 924 but said no, not enough room for her mates.) _________________ Porsche 924 1984 (UK import) NA
J1NX3D
Posted: Thu Aug 17, 2006 6:40 pm Post subject: |
| Ozzie wrote: | | (offered her a 924 but said no, not enough room for her mates.) |
but thats perfect!! she'll get in less trouble that way! _________________ '86 944 |
Posted: Thu Aug 17, 2006 7:19 pm Post subject: |
Yeah I know....grumble...grumble. _________________ Porsche 924 1984 (UK import) NA
