Valve Cover
isuras2
PostPosted: Thu Aug 17, 2006 4:56 am    Post subject: Valve Cover Reply with quote
Is it possible to remove the valve cover with just removing the bolts? Or does the dizzy need to be removed, adjusted to allow more room. Mine seems to be caught on the dizzy vacuum advance part.
Thanks,
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
StienbargerR
PostPosted: Thu Aug 17, 2006 11:50 am    Post subject: Reply with quote
Can you pull the vacuum tubes?
Ryan
1978 924 NA
isuras2
PostPosted: Thu Aug 17, 2006 12:40 pm    Post subject: Reply with quote
The tubes are not the problem, where they connect on the dizzy is the problem.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
leadfoot
PostPosted: Thu Aug 17, 2006 12:51 pm    Post subject: Reply with quote
Yes you do not need to remove the dissy...
but in you case you may need to rotate it, in which case you will need to reset you timing upon refitting of the cover, it sounds like you sparks plug wires may be in the wrong holes in the dissy cap, not out of order though...
Leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
PostPosted: Thu Aug 17, 2006 5:19 pm    Post subject: Reply with quote
Like leadfoot says you can do it without removing the dizzy, but I reckon it's easier if you do. Re-timing the ignition is no hassle and is a regular job anyway.
isuras2
PostPosted: Thu Aug 17, 2006 9:41 pm    Post subject: Reply with quote
Thanks guys. I'll see what I can do.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Thu Aug 17, 2006 10:19 pm    Post subject: Reply with quote
I've never had to remove or even pivot the distributor to pull the valve cover - I wonder if your distributor is clocked incorrectly on the head? You know, the way the distributor housing can be bolted on in two positions, resulting in two different angles... one more upright and closer to the hood, the other more laid-over...
isuras2
PostPosted: Fri Aug 18, 2006 1:52 am    Post subject: Reply with quote
Hmm...I'll have to look into that.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
pmohr
Guest
PostPosted: Fri Aug 18, 2006 9:42 am    Post subject: Reply with quote
Which way is more...'correct'?
PostPosted: Fri Aug 18, 2006 10:24 am    Post subject: Reply with quote
more laid over,
if it is in the more upright position it will hit the hood and decrease the life.
3 928s,
