Desolation
Posted: Sun Jul 23, 2006 12:56 pm Post subject: Another what the heck? |
Hmm, I know it takes the fuel to different places but I need to get it rebuilt/ or a new one and I don't know what the name is for it.. anyone know what its called? Oh and the orange/red stuff appears to be something the PO used to try to stop fuel leaks... Heh.. I don't think it worked either cuz there is fire extinguisher residue in there  _________________ 1977 924 - sold
1989 Mustang
My MySpace ^_^ |
Chrenan
Posted: Sun Jul 23, 2006 1:08 pm Post subject: |
That's the fuel distributor. They are no longer available new. Some members have tried rebuilding and bought rebuilt with varying levels of success. If a car sits for a long time, the fuel can turn to jelly inside the fuel distributor, and folks open them in an attempt to clean. It splits horizontally into 2 pieces and is very difficult to seal again once opened. Your previous owner may have failed in his rebuild attempt, thus the leaking.
The fuel line attachement with the orange gunk on top of it clearly has the wrong size washer. It should have a very thin copper crush washer. You can go to your porsche dealer and get a palm full for a few bucks. Undo all the fuel lines from the distributor and make sure there is a crush washer on either side of the banjo fitting then torque to spec. _________________ 1987 951 - M193 Version for Japan |
Desolation
Posted: Sun Jul 23, 2006 3:20 pm Post subject: |
Hmm..Alright, Yeah they just tried to use the orange stuff for a gasket/seal too. MMm so I should probably take it to a mechanic you think and get them to rebuild it ? _________________ 1977 924 - sold
1989 Mustang
My MySpace ^_^ |
StienbargerR
Joined: 28 Oct 2005 Posts: 1362 Location: Richmond, IN
Posted: Sun Jul 23, 2006 3:29 pm Post subject: |
It might be cheaper and better to go with an aftermarket EFI or something. Seems like if you want other upgrades, thats a big thing you will need anyway. I would do it if I had the money.
Ryan _________________ 1978 924 NA
-250lb lowering springs, Euro Pistons |
Desolation
Posted: Sun Jul 23, 2006 3:36 pm Post subject: |
How would I go about getting something like that and about how much would it cost you think? _________________ 1977 924 - sold
1989 Mustang
My MySpace ^_^ |
StienbargerR
Posted: Sun Jul 23, 2006 3:39 pm Post subject: |
Im not really sure, Im no expert on it really, just search EFI on the board search, and it will come up with something.
Joined: 29 Jul 2001 Posts: 2743 Location: Sydney, Australia
Posted: Sun Jul 23, 2006 4:52 pm Post subject: |
| Desolation wrote: | | MMm so I should probably take it to a mechanic you think and get them to rebuild it ? |
Not just any mechanic. They're tricky little things. Very few mechanics would know what to do with one. Check around and check references. _________________ 1979 924 (Gone to a better place)
Chrenan
Posted: Mon Jul 24, 2006 12:54 am Post subject: |
Peter is correct, finding a mechanic willing to rebuild a CIS distributor will be tough. Lots will work on CIS cars as the system is used in lots of VW, Audi, Volvo etc cars of the same era, but rebuilding the distriubtor is a whole different story. The easiest thing to do would be to find a running (or very recently running) 924 of the same year and get the fuel distributor out of this car and swap it into yours. Try a pick-a-part place or maybe there is a cheap parts car in your area? _________________ 1987 951 - M193 Version for Japan |
Desolation
Posted: Mon Jul 24, 2006 2:46 am Post subject: |
Man that stinks...I'll have to figure somethin out.. Btw, what does CIS mean? _________________ 1977 924 - sold
1989 Mustang
My MySpace ^_^ |
Chrenan
Posted: Mon Jul 24, 2006 2:53 am Post subject: |
"Continuous Injection System" since fuel is continually atomized into the manifold just before the intake valve. Fuel is controlled by airflow past a pressure plate which moves a plunger inside the fuel distributor which regulates fuel flow. _________________ 1987 951 - M193 Version for Japan |
Desolation
Posted: Mon Jul 24, 2006 8:18 am Post subject: |
I see, thank you for the explanation. _________________ 1977 924 - sold
1989 Mustang
My MySpace ^_^ |
Desolation
Posted: Tue Jul 25, 2006 2:52 am Post subject: |
I found the numbers on the side of the fuel distributor and I wanna know if they are the right ones? it said Bosch right above them, which would I use to find my part?
0 438 120 066
047 133 353 C
823 _________________ 1977 924 - sold
1989 Mustang
My MySpace ^_^ |
D Hook
Posted: Tue Jul 25, 2006 10:32 am Post subject: |
You might want to post the year of your car in your signature line by your name. That way, if someone has the part you're looking for, they'll chime in (maybe). I've got a fuel distributor but it's for an '80, don't think it will match up.
Try to find one that's been removed and stored or one from a car that's been running recently, as someone else mentioned because those things get gummed up if the fuel sits in them too long and that's what causes the rebuild, which is almost impossible to do because of the sealing problems. There are places that will do a rebuild for you and places that sell rebuilt ones but they're not cheap, if you can find one.
BTW, do you have a Haynes manual yet? If not, let me know; I've go a couple brand new ones sitting in my garage. _________________ '80 924 n/a SOLD |
Posted: Tue Jul 25, 2006 11:29 am Post subject: |
My Haynes manual is covered with greasy smudges and beer stains, plus, part of it was eaten by mice....
Name your price. _________________ White 87 924S "Ghost"
D Hook
Posted: Tue Jul 25, 2006 11:32 am Post subject: |
You kiddin' Paul?! That things just getting broke in!
PM me your address and it'll be on its way. Orange cover. _________________ '80 924 n/a SOLD |
