windows/headlights
kewpie79
PostPosted: Mon Jul 17, 2006 4:24 am    Post subject: windows/headlights Reply with quote
First the windows, replaced the relay and fuse, still nothing- not going down.
Headlights, new relay,switch, different motor (tried three different ones) parking lights come on, no headlights (replaced lamps with new ones thought old ones could have been burned out). Will cycle through, but will not stay up. any ideas?
1980 Porsche 924
1984 Pontiac Grand Prix
2003 Kia Sorento
Slam
PostPosted: Mon Jul 17, 2006 7:38 am    Post subject: Reply with quote
Did you change the relay at the motor and the one under the dash for the headlights?
dpw928
PostPosted: Mon Jul 17, 2006 8:21 am    Post subject: Reply with quote
It sounds like the motor. There is a circular plate inside that shoul cut power to the motor when the headlights are in the up position. Are you sure you are using the correct versions on the relay and motor for your model year?
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
StienbargerR
PostPosted: Mon Jul 17, 2006 11:20 am    Post subject: Reply with quote
try the window switches...I think it has been mentioned numerous times that the switches are what go bad on the windows.
Ryan
1978 924 NA
kewpie79
PostPosted: Mon Jul 17, 2006 1:02 pm    Post subject: Reply with quote
I changed the relay on the motor itself
1980 Porsche 924
2003 Kia Sorento
Stampedetrail
PostPosted: Tue Jul 18, 2006 5:30 pm    Post subject: Re: windows/headlights Reply with quote
If they go up & back down & stop or continuously cycle it is likely that one or two of the diodes attached to the h/l motor is fried. Fix this with some new diodes from radio shack (or cannibalize a kereoke machine like me). If they continuously cycle you may have the former at fault; easy to test with a volt-meter-- check resistance both ways across the diodes. I'd say take off the motor to preform the tests, and dont put it back on until you're certain it is either broken or working as designed. Also, and this one is dirty but necessary, crawl under the dash with a flashlight with your head on the clutch and check out the wiring to the headlight switch. Possibly it is a melted wad of plastic, shorting out a lot of crap. You can disconnect the switch from the dash from there & get a better look.
1977.5 924 "Martini" head / New Old Stock rebuild
1985.5 944 Why? Because I can.
