Dogteeth - G31 Dogleg
pez
PostPosted: Fri Jul 07, 2006 10:50 am    Post subject: Dogteeth - G31 Dogleg Reply with quote
Roger @ powerhaus II is fabricating dogteeth for 1st, 2nd & 3rd - the nice gent that he is. Approx 90 day lead time !
I believe price will be ballpark US$150 per unit.
If you're in the mkt put your requirement here... I'll point Roger to this thread later !
I'm taking 2x 1st, 2nd & 3rd.
CGT #330 - & she's all mine....
Raceboy
PostPosted: Fri Jul 07, 2006 3:08 pm    Post subject: Reply with quote
I'm in for the dog-teeth (1st, 2nd and 3rd).
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
PostPosted: Fri Jul 07, 2006 10:21 pm    Post subject: Reply with quote
That's a dayum good price, IMO! Thanks for the FYI (though I don't use that box anymore)...
Keaton
PostPosted: Wed Jul 12, 2006 7:54 am    Post subject: Reply with quote
whats special about dogteeth gears?
-nick
PostPosted: Wed Jul 12, 2006 8:46 am    Post subject: Reply with quote
Hey Pez,
I missed this the first time around. I can't committ to anything in the short term, but I will absolutely pick up a 1st gear dogteeth gear in the future.
How did you manage to convince powerhaus to tool these up?! This is a great service for anyone with a G31. It makes the transaxle worth keeping.
ps - Keaton, the G31 dogteeth wear notoriously badly and aren't available outside of a complete gearset (to the tune of ~$1500 if I recall). Thus the need for replacements.
nick
PostPosted: Wed Jul 12, 2006 11:54 am    Post subject: Reply with quote
As always they become available when someone thinks there is enough demand to make some money selling them....
CBass
PostPosted: Wed Jul 12, 2006 5:20 pm    Post subject: Reply with quote
Now am I correct in thinking you only really NEED the dogteeth if your car has a habit of popping out of gear?
Or are the synchros and dogteeth integrated?
PostPosted: Thu Jul 13, 2006 1:06 am    Post subject: Reply with quote
worn dog teeth can cause trouble getting into gear, and if it doesnt fully engage then yes can cause gear pop out,
and no the syncro rings are not integrated.
3 928s,
endwrench
PostPosted: Thu Jul 13, 2006 2:15 am    Post subject: Reply with quote
To my knowledge, popping out of gear is usually a sign of bad alignment due to worn bearings\bushings or actual bad gears.
After pulling one of these tranny's apart I have to say the dogteeth are not really the problem but they are the symptom. The syncro rings and slider gears are the problem. If they don't get things up\down to speed before the dogteeth engage then bye-bye dogteeth. Infact, I think new dogteeth without new syncro rings and slide gears will actually make things worse. My 2 cents.
BTW, anyone know were I can get some rings?
Todd
-nick
PostPosted: Thu Jul 13, 2006 5:02 am    Post subject: Reply with quote
hey Todd
I picked up my 1st gear syncro from the notorious Partwerks of Chicago. Their reputation is the pits, but they might have some lying around still. I think that as long as you don't buy their used parts, and stay away from their ebay auctions, then you're ok.
2nd and 3rd I got from one of those thepartsbin.com spin-offs who don't seem to be around anymore (something like performanceparts.com). partsbin lists some trans internal parts, but no syncro's anymore.
That's about all the help I can give
pez
PostPosted: Wed Sep 13, 2006 2:58 pm    Post subject: Reply with quote
There has been a slight delay in completing the run of 1st gear dog rings due to confusion regarding which way the asymmetric tooth runs. Does anyone know if the tooth points clockwise or counter clockwise?
2nd & 3rd are done
-nick
PostPosted: Thu Sep 14, 2006 12:26 am    Post subject: Reply with quote
Not sure, but maybe you can figure it out from here -
http://www.m-elliott.us/Porsche/G31Rebuild.htm
Great work on 2nd & 3rd !!!
1980 931S
1991 964 C4 Cabriolet
pez
PostPosted: Thu Sep 14, 2006 9:59 am    Post subject: Reply with quote
thx... don't worry we're good. They've figured it out - about 2 wks for 1st gear
-nick
PostPosted: Tue Jan 09, 2007 5:17 am    Post subject: Reply with quote
Pez you're legendary!
I just picked up the last 1st gear G31 dogteeth ring in the world from PH-II
I'm sure they would make another run if the demand is there.
I pulled the trans apart over the weekend and found my 1st gear teeth worn down to nubs. There wasn't much more than that in there when I put together the last time. The syncro ring looks like it hasn't worn at all - probably because it's only in contact with 1/16" of teeth
This ought to make a world of difference shifting into 1st. woohoo!
1980 931S
PostPosted: Tue Jan 09, 2007 7:04 am    Post subject: Reply with quote
Whats up with the gear-tranny-issue 1 ?
My part is original, has 476000 Km on and is still good to go some more......by the way its a 4 gear! Audi Quality!
Buy parts or drive automatic `s !!!
Quick shift Nobbi
