ossaman55
Joined: 20 Feb 2006 Posts: 50 Location: Imlay City, Michigan
Posted: Sun Jun 11, 2006 1:23 am Post subject: Turbo Gaskets |
I just got my rebuilt turbo today. I now need the large o ring to go on the pressure duct as well as the gasket that goes between the upper duct and the pressure tube. A exhuast manifold to turbo gasket is aslo needed. Does anyone know where i can get a gasket set to get my turbo back on. I cant wait to see what it feels like to drive a healthy 931. _________________ Darren
1980 931
1984 Maserati Biturbo
1978 Triumph Spitfire
1986 Camaro Z28 |
numbbers
Posted: Sun Jun 11, 2006 10:05 am Post subject: |
Well, try your dealer. But, I don't believe that the gasket between the lower and upper turbo ducts is available anymore. You may have to make that one. _________________ 1980 924 Turbo |
Posted: Sun Jun 11, 2006 10:10 am Post subject: |
You will also need the 2 green O rings if you have disturbed the turbo mount (on the center section). _________________ White 87 924S "Ghost"
MunkPuppy
Joined: 02 Jul 2003 Posts: 419 Location: New Westminster, B.C., Canada
Posted: Mon Jun 12, 2006 2:56 pm Post subject: |
I got the O-Ring size from the online PET (47mm X 5.7mm), brought my old O-Ring as well, and went to my local auto parts shop and compared sizes to what they had in stock. I bought a few O-rings, thicker than the old one, since it had worn out past usefulness. Then I tried them one at a time and found the one that fit snug yet still allowed the lower charge tube to go on with only moderate resistance.
Try to get rings with higher-temp rubber (usually orange-colored); I got the regular rubber and I can't help but wonder if it could get a little too soft from the turbo's heat. _________________ '80 931 FOR SALE
-Anton Szandor LaVey |
numbbers
Posted: Tue Jun 13, 2006 1:51 pm Post subject: |
If it is just standard rubber, my guess is it will meld into goo. _________________ 1980 924 Turbo |
924guy
Posted: Fri Jun 16, 2006 9:55 pm Post subject: |
i "might" have the sleeve you need. i will check later today. the sleeve for the 79-80 and 81-82 is different, i ordered the later and got the former and couldnt return it, it was expensive . if all else fails, the blue silicone sleeves they sell for turbo ducting should work. thats probably the route ill go since the sleeve i need cant be found. for now i resealed the old one and wrapped it in rubber tape. ill be pulling my engine soon so it wasnt a big deal.
the orings seem to still be available though, those should be orderable . _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
numbbers
Posted: Sat Jun 17, 2006 9:54 am Post subject: |
| 924guy wrote: | i "might" have the sleeve you need. i will check later today. the sleeve for the 79-80 and 81-82 is different, i ordered the later and got the former and couldnt return it, it was expensive . if all else fails, the blue silicone sleeves they sell for turbo ducting should work. thats probably the route ill go since the sleeve i need cant be found. for now i resealed the old one and wrapped it in rubber tape. ill be pulling my engine soon so it wasnt a big deal.
the orings seem to still be available though, those should be orderable . | What is the "sleeve"? _________________ 1980 924 Turbo |
macBdog
Posted: Sat Jun 17, 2006 6:54 pm Post subject: |
You must use some kind of high temperature oring for the turbo oil supply. I used standard and they melted into goo from one drive. The dealer is the only place I have been able to find them. Also make sure you follow the manual's tightening sequence otherwise the joint will leak, new O rings or not. _________________ 1979 931 with a 350 chev
1973 911E with EFI
ossaman55
Posted: Mon Jun 19, 2006 12:09 pm Post subject: |
Thanks for all the help. I found the gaskets online at porsche-parts-direct.com I finished the turbo install today. Now to fix the short that causes the fuel pump to cut out and install a new cold start valve. _________________ Darren
1980 931
1986 Camaro Z28 |
