flosho
Posted: Sat May 20, 2006 3:11 am Post subject: Boost Controller, worked, now over boosting? |
I installed a brass needle valve off ebay and it seemed to work good for about 3 days. This week however, I went out for a cruise and pushed my car a bit harder than normal and now my car is overboosting badly... meaning I changed nothing on the boost controller however its hitting 15+psi if I hammer on it(obviously I don't hammer on it now since 15-20 psi is not safe)
I spliced it in to the wastegate line and used some rubber fuel hose as the extending piece.
So far to remedy this I have:
Switched the boost controller to another (same style) boost controller.
Switched the hose that I used.
Could it be possible that the rubber fuel hose is expanding? and delaying the signal to the WG even more? The only other thing I could see that is happing is one of the hoses isn't clamped to the boost controller any more because I stripped the clamp, but all other connections are clamped.
I did return it to stock, with just a splice piece in and it boosted to 7psi like it should stock.
Here's a pic of the setup I'll get a better one shortly..
http://i73.photobucket.com/albums/i211/flosho924/159_5570.jpg _________________ [This Space For Rent] |
Belgian924t
Posted: Sun May 21, 2006 8:55 pm Post subject: |
I think that your used fuellines are expanding which fool the controller. _________________ '79 931 with Carrera GT look
'86 944 turbo (sold)
'88 944 turbo S (sold)
'85 911 Carrera 3,2 (to be restored)
'80 911 SC "SOLD"
http://www.cardomain.com/ride/2224272 |
flosho
Posted: Mon May 22, 2006 12:36 am Post subject: |
That may be.
I've switched to a stiffer rubber hose, that is also shorter.. I think I got it working now. Its set to 8psi or so and working fine now and I ran it for 2 good hours on friday night and nothing went wrong..  _________________ [This Space For Rent] |
