Hot Starting????
martin924
PostPosted: Wed May 17, 2006 5:22 am    Post subject: Hot Starting???? Reply with quote
My 21 year old 924 runs mint, just serviced her and all is good apart from hot starting, when left for only a couple of mins no problems, but 5mins to an hour or over and she does like starting at all, is it a fuel evapouran problem? Is there a way to fix it, if not is it best to floor the gas pedal until she finally springs back to life or not??? Apart from that, its the most fun on four wheels i have ever owned im well pleased,
PostPosted: Wed May 17, 2006 6:22 am    Post subject: Reply with quote
There are several check valves that when working, hold pressure in the fuel system after shutdown to prevent vapour lock. One or more of them must be leaking pressure. One is a check valve at the outlet of the fuel pump. Another is at the primary pressure regulator that's built into the fuel distributor. Fuel injectors may also leak - both the 4 CIS fuel injectors and the CSV (cold start valve). The fuel accumulator/s are another possible source of the problem. Until you find the leaky component/s and fix, yes, hold the throttle to the floor while cranking to clear the vapour lock quicker.
martin924
PostPosted: Wed May 17, 2006 6:44 am    Post subject: Will this fit?? Reply with quote
Thank you for your reply, sounds like a bit of a job, the fuel pump does wistle and whine on tickover, and i have found a brand new bosh 0 580 254 909 in the glove box!, but according to the web i should have a bosh 0 580 254 053. same connections and size and 5 bar pressure but the ## 909 is 148 liters per hour and the correct one ## 053 is a higher output of 175 liters per hour, will this work?? Thank you so much for any help, Regards Martin
timstar92404
PostPosted: Wed May 17, 2006 8:43 am    Post subject: Reply with quote
don't touch the gas pedal when cranking it can backfire and blow off your intake hoses and then you could be stuck if you don't have a screwdriver.
someone told me fuel pump checkvalve or fuel accumulators are most likely the problem.
78 924 sold.
85.5 944
PostPosted: Wed May 17, 2006 5:48 pm    Post subject: Reply with quote
After shutdown the heat from the engine causes the fuel in the lines to try to vaporise and the pressure forces fuel to return to tank.
Areas to check are fuel pump non return valve, accumulator, fuel lines, and primary pressure regulator, warm up regulator, CSV and injectors.
Any of these or any combination which allows pressure to either return to tank or escape (into the intake manifold or atmosphere) will cause this problem.
TheFuzz89
PostPosted: Thu May 18, 2006 5:13 am    Post subject: Reply with quote
that is scary that you say that, because for mine to ever start i have to sit and crank the key and pump the gas pedal like mad sometimes (it still has the hot start problem) but normally it will start right up that way (if cool enough).
1977 Porsche 924
PostPosted: Thu May 18, 2006 6:55 am    Post subject: Reply with quote
I wouldn't take the backfire as gospel.. I would suspect Timstar couldn't time his car properly.
leadfoot
PostPosted: Thu May 18, 2006 12:58 pm    Post subject: Reply with quote
It says in the owners manual that this is exactly what your meant to do...
Put your foot to the floor and crank it over till it starts...
Leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
Eturbo924
PostPosted: Fri May 19, 2006 6:47 am    Post subject: Reply with quote
You can also wire a push button onto your cold start valve so you can fire it. It works perfectly in my 1977. I did not wire it up though.
1992 968
2003 C4S
E-mail me for parts you need!
Drive Fast!
P924
PostPosted: Sat May 20, 2006 12:36 am    Post subject: Reply with quote
Works indeed .
911T 2.2
skemcin
PostPosted: Sat May 20, 2006 12:58 am    Post subject: Reply with quote
P924 wrote:
Works indeed .
Isn't there a DYI write up here on the board for this?
924.org (no time to complete)
9249206347 - 8k – waiting its resurrection, no power at the fuel pump and fuse #7 blows w/power
P924
PostPosted: Sat May 20, 2006 1:02 am    Post subject: Reply with quote
skemcin wrote:
P924 wrote:
Works indeed .
911T 2.2
Eturbo924
PostPosted: Sat May 20, 2006 1:37 am    Post subject: Reply with quote
http://www.924.org/techsection/hot_start_problem_fix.htm
1992 968
2003 C4S
Drive Fast!
martin924
PostPosted: Sun May 21, 2006 3:09 am    Post subject: Many thanks. Reply with quote
Thank you for the link about puting a switch on the cold start value, thats just what il do!
dpw928
PostPosted: Sun May 21, 2006 6:58 am    Post subject: Reply with quote
The hot start button will work if the fuel pressure loss is back into the tank. If the loss is due to leaking injectors, it will make it worse.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
