Temp sensor possibly gone...
White Pony
PostPosted: Thu May 18, 2006 10:38 am    Post subject: Temp sensor possibly gone... Reply with quote
The temp sensor has possibly gone on my 924. If I take the wires off of it and create a bridge between the two, the fans start up... But they do not start up on their own unless I turn on the A/C. So the relay is good...
Anyone know how big of a job it is to fix? I want to DIY if possible. I have a little project car (85 Caddilac Eldorado) that needs some road time, I can put liscense on that for awhile if it is a big job.
1987 Porsche 924S
White/black (The White Pony)
For sale, $1000
http://www.924board.org/viewtopic.php?p=173801#173801
Stu2j
PostPosted: Thu May 18, 2006 10:58 am    Post subject: Reply with quote
Sorry that I can't help with your problem but I just thought this was tooooo funny ...
Mods:
Rock chips, water damage, cracks, dents...
-Stu
924 owner since 1988
924S owner since 2002
Click here to view them:
PostPosted: Thu May 18, 2006 11:41 am    Post subject: Reply with quote
It's most likely bad, but new ones are cheap!
If you want to make sure, pull it, put it in a pan of water and heat it up with a ohm meter attached.
It's an easy job, just top off the coolant tank when you are done and bleed the system.
White Pony
PostPosted: Fri May 19, 2006 12:33 am    Post subject: Reply with quote
How do I get to it, from below the car or from above? And does it just screw in to the radiator?
I will order one as well as some other parts just in case becuase it's cheap, even if it is not broken it will save some time to already have it.
1987 Porsche 924S
For sale, $1000
PostPosted: Fri May 19, 2006 11:31 am    Post subject: Reply with quote
Yes you just remove the wires and unscrew it. A socket works best, but whatever you use, after the first 1/2 of a turn, you'll be able to do the rest by hand.
Remove the air cleaner support bracket to gain access. Doing it from the top has the advantage of nothing will drip in your face.
Do this when the car is ice cold and with the coolant cap on tight. If you're quick, you will lose very little coolant.
White Pony
PostPosted: Fri May 19, 2006 12:00 pm    Post subject: Reply with quote
Cool! Sounds easier than I thought, I figured I would have to pull the entire radiator. For now I'm just running it with the AC on, the fans have to run anyway when it's on. THe belts squeal alot because of the extra load, but it doesn't overheat I will try to take pics of the job for future reference of others with the same problem.
1987 Porsche 924S
For sale, $1000
PostPosted: Fri May 19, 2006 12:04 pm    Post subject: Reply with quote
It's a tight fit, wear gloves to protect the back of your hands.
PostPosted: Fri May 19, 2006 6:33 pm    Post subject: Reply with quote
I would replacing the temperature switch first, since it is cheap, and you can upgrade to the lower temperature activating switch.
If that does not cure the problem, then you could have a defective cooling fan relay, or a defective ac relay.
White Pony
PostPosted: Thu May 25, 2006 1:23 pm    Post subject: Reply with quote
does anyone have a link to where i can buy the part? the ones on paragon say "in the block" temp sensor... looking again on Pelican now, I don't remember seeing it though
man my baby is fallin apart fast... on top of chuggin up hills from bad plug wires, having shot brakes now it's starting to shift real hard into second gear and the parking brake is completely shot, so I have to walk like 10 minutes now to work cause I can't park on a hill.
1987 Porsche 924S
For sale, $1000
