924S cookie cutter wheels offset
drumboxer
PostPosted: Thu May 04, 2006 1:50 am    Post subject: 924S cookie cutter wheels offset Reply with quote
I have a 1988 924S and I am trying to fit 15x7 inch wheels onto the car for 944 spec racing. I know that my two options are cookie cutters or phone dials. I have located a set of cookie cutters which are the proper size, but they are from a 72-86 911, rather than a 944. Will these wheels fit on my car? I believe that have a different offset, but I do not know if this will effect their fitment. Thanks
Rule #76: No excuses, play like a champion.
genikz88
PostPosted: Sat May 06, 2006 12:08 am    Post subject: Re: 924S cookie cutter wheels offset Reply with quote
I'm assuming you mean 944 Spec with NASA. I am also building an 88 924S for the SoCal region.
Have you tried posting in the 944 Spec forums at nasaforums.com? You can usually find offset info at discounttire.com or tirerack.com too.
Chris
'88 924S
PostPosted: Sat May 06, 2006 5:42 am    Post subject: Reply with quote
Cookie cutters were not available in 1972. The offset on 911 wheels changed before 1986. You need to know the offset of the cookie cutters and/or the part number that is cast on the rear of the wheels before anyone can help you. 924S never came with cookie cutters, so depoending on what class you want to run, may not be legal. I have a set of Porsche TB Manuals, and I can see if the wheels will fit by the part number if you can get the part number. The 72 911 did not use 7 inch wheels, and the 6 inch phone dials that they use have a different offset from the 6 inch phone dials that came on 924S. The centers on the 6 inch 911 wheels stick out way further than the rims on the front than the 924S phone dials and they look funny, similar to the appearance of 928 7 inch phone dials. You should also be aware that cookie cutters are heavy wheels compared to phone dials, similar to the difference between the ATS cast BBS lookalike "basketweave" wheels and phone dials.
924S_DRFTR
PostPosted: Fri May 12, 2006 6:35 am    Post subject: Reply with quote
yea they will fit i have an 87' 924s with cookie cutters check out my ride ... but i had to get 195/60/15's in front and 205/60/15's so it wouldnt rub ... because the tires that were on it was too big n rubbed they were 215/60's
I stay goin' slidewayz..
87' 924S - 15" Cookie Cutters
http://www.cardomain.com/ride/825579
924S_DRFTR
PostPosted: Fri May 12, 2006 6:36 am    Post subject: Reply with quote
Manning
PostPosted: Mon May 15, 2006 12:59 pm    Post subject: Reply with quote
Yeah, um, those cookies in your pictures don't really fit. The proper offset for a 924S is 52.3mm. Cookies have an offset of 23.3mm for early 944 or pre-1990 911.
Michael Manning
1988 924S Undergoing weight loss program
grainginer11
PostPosted: Sat May 20, 2006 9:51 pm    Post subject: Reply with quote
Check the ET on these wheels...You can go untill 36mm with no problem.
If the ET is 23mm,you just can't use them.
Good luck!
Kens_74_911s
PostPosted: Tue May 15, 2012 8:31 am    Post subject: 15x6 cookies et36 Reply with quote
Old thread re visited... The 15x6 cookies are et 36 anyone run those on a 924s? I have 6 of them and a guy asking If the 15x6 will fit his 924s . Did the 924s get caught up in the early Vs late offset mix that the 944 -85 VS 87 Did ?
Ken
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s widebody
96 BMW 750iL
99 BMW 328i
81 VW MK1-1.8 GTI, 5 spd Pickup
02 Explorer (wife's)
92 BMW 735iL Parting
84,85,86x3,87,944. 82-924,88-924s parted
68, 70, 72, 73, 911~ 70,73 914 past Pcars
PostPosted: Tue May 15, 2012 12:12 pm    Post subject: Reply with quote
Cookies are not the proper offset for a 924S. They can bolt up (and Khal runs them on his 932), but if you are in a position where you are expected to guarantee proper fitment/no rubbing, don't.
