| Sell the 924 and back-up car for a Lancia? |
| Yes, ditch the b!tch |
22% |
[ 2 ] |
| No, stick with it till you are broke |
77% |
[ 7 ] |
| Total Votes : 9 |
N-Dub
Joined: 16 Jan 2006 Posts: 219 Location: Salt Lake City, Utah
Posted: Sun Apr 30, 2006 2:02 am Post subject: My Serpentine (or whatever) Belt Broke!! |
So I was out on a joyride with my father and heard a pecular squeel coming from the engine bay. I ruled it out as just a squeeky belt and kept driving. I watch my gauges probably more than I check my mirrors, and the voltage gauge starts to go down a bit. THis was interesting but had happened before. The battery light turned on. Once again interesting but hadn't ever happened before. The temperature gauge was on the rise and not stopping. Luckily I was within a quarter mile from my house when the temp went in and off of the red. A suspicious popping sound had just started. So we coasted almost all the way home with the heater on. I popped the hood when I got home to see the Audi, he he he, coolant tank's fluid boiling. Now I am smart enough to not open the lid while it is boiling, so I got a fan to aid the cars fan. I found bits of the belt in the engine bay, but the main belt was gone somewhere down the road.
How much should a new belt run?
Is it so easy as to unbolt the alternator and slip on the new belt?
Input would be appreciated,
Nate _________________ '79 924 now Totaled! Carrera GT bodywork for sale!
'87 951 |
Tigger937
Posted: Sun Apr 30, 2006 2:29 am Post subject: Re: My Serpentine (or whatever) Belt Broke!! |
| N-Dub wrote: | How much should a new belt run?
Nate |
Be thankful it wasn't the timing belt.
Belts are cheap, $10-$20. Just loosen the alternator mounting bolts, slide it over, slip the belt on and tighten.
Hopefully the cylinder head gasket didn't lose seal from the overheat. _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
Joined: 29 Jul 2001 Posts: 9115 Location: Royal Oak, MI, USA
Posted: Sun Apr 30, 2006 2:47 am Post subject: |
Yeah, uh, people, pay attention!!! How many occurrences of this have we had in the past couple of months?? Somebody loses the belt for the waterpump and alternator, sees all the signs, keeps driving through the overheat, and wonders if they can get away with just replacing the belt???
GET WITH THE PROGRAM, PEOPLE!!!
Do NOT drive the car when the temp's in the RED, unless you LIKE doing headgaskets!!! WTF!?! I can swap them in 3 hrs, and I still don't like doing them.
REPLACE YOUR BELTS NOW, if you haven't already. There's no excuse for this kind of failure. Just how flexible and functional do you think rubber is after 20 years??? Would you drive on 20-year-old tires?? I sure as hell hope not.
And the belts are cheap and easy to replace. IF you don't know how old they are? Pitch 'em. Timing belt's around $8USD, alt/water pump belt is around the same. You need these to keep driving your car.
Plan ahead, or suffer the consequences.
'Nuff said. _________________ Vaughan Scott
Posted: Sun Apr 30, 2006 2:48 am Post subject: |
PS - if you can't keep track of replacing stuff like belts on a 924 - you're definitely not up for handling any Italian machinery... _________________ Vaughan Scott
N-Dub
Posted: Sun Apr 30, 2006 7:42 am Post subject: |
Just for the record, 924RACR, I didn't overheat. _________________ '79 924 now Totaled! Carrera GT bodywork for sale!
'87 951 |
Posted: Sun Apr 30, 2006 8:33 am Post subject: Re: My Serpentine (or whatever) Belt Broke!! |
| N-Dub wrote: | The temperature gauge was on the rise and not stopping. Luckily I was within a quarter mile from my house when the temp went in and off of the red. A suspicious popping sound had just started. So we coasted almost all the way home with the heater on. I popped the hood when I got home to see the Audi, he he he, coolant tank's fluid boiling.
Nate |
Dude, this is the definition of overheating! _________________ White 87 924S "Ghost"
Posted: Sun Apr 30, 2006 8:36 am Post subject: |
You will need to replace the belt and bleed the cooling system and hope like hell that you have not warped your cylinder head.
NEVER DRIVE A CAR WITHOUT A WATER PUMP BELT!!!
Once again the idiot lights are smarter than the driver. _________________ White 87 924S "Ghost"
Chrenan
Posted: Sun Apr 30, 2006 8:38 am Post subject: |
Agreed, that is overheating. _________________ 1987 951 - M193 Version for Japan |
Tigger937
Posted: Sun Apr 30, 2006 8:49 am Post subject: |
N-Dub, unfortunately, these cars are very sensitive to overheating. Once the needle hits the red, usually it's too late. The fact the coolant started boiling and you had a popping sound is not a good sign. I would not get my hopes up. You're probably going to need a head gasket at the very least. If not, consider yourself lucky.
All you can do now is replace the belts, top off the coolant, bleed the cooling system and test it out while keeping a close eye on the coolant level and looking for excessive pressure buildup in the overflow tank, oil in the coolant and/or coolant in the oil. The damage, if any, will already have been done.
| N-Dub wrote: | Luckily I was within a quarter mile from my house when the temp went in and off of the red. A suspicious popping sound had just started.
Now I am smart enough to not open the lid while it is boiling, so I got a fan to aid the cars fan. |
Hopefully, these actions saved your head and gasket. Good luck. _________________ 1981 931 (Concours)
Posted: Sun Apr 30, 2006 8:59 am Post subject: |
You should drain your oil before doing anything else and see if there is any coolant in it. Ignore this and you may need new rod and main bearings very soon. _________________ White 87 924S "Ghost"
Posted: Sun Apr 30, 2006 9:03 am Post subject: |
BTW it is very common for a water temperature gauge to actually read lower once the coolant starts to boil. It was designed to measure the temperature of a liquid, not air pockets. _________________ White 87 924S "Ghost"
D Hook
Posted: Sun Apr 30, 2006 1:28 pm Post subject: |
Before you slip on the new belt maybe you ought to see why the old one broke. Water pump or alternator locked up?
BTW, you need to add more choices to your poll.  _________________ '80 924 n/a SOLD |
timstar92404
Posted: Sun Apr 30, 2006 7:45 pm Post subject: |
that happened to me before but I was like 2 minutes from home the belt wasn't tight enough and it came off, I didn't know while driving, my battery light came on and I thought my alternator was bad.
belt is easy to change, you adjust the tightness of the belt my moving the alternator _________________ 78 924 sold.
85.5 944 |
Posted: Sun Apr 30, 2006 10:32 pm Post subject: |
Paul's right.
Having the belt come off, rather than break, is far more likely and common - this can be caused by old, worn out alternator bushings allowing the pulleys to be misaligned. However, there's no good reason to keep driving it hot. Even my mother knows better than that - she parked it and called me!!! It's right in the owner's manual - turn it off and let it cool fully before driving again. _________________ Vaughan Scott
Stu2j
Joined: 03 Nov 2002 Posts: 1285 Location: Virginia Beach, VA
Posted: Tue May 02, 2006 12:25 am Post subject: |
| 924RACR wrote: | | However, there's no good reason to keep driving it hot. |
This is why newer cars will simply shut off if they overheat. _________________ -Stu
924 owner since 1988
924S owner since 2002
Click here to view them: |
