I hate recurrent electrical crap problems
PostPosted: Thu Apr 27, 2006 10:12 pm    Post subject: I hate recurrent electrical crap problems Reply with quote
So my 931 sat over the winter (imagine that), and I think some water worked its way in due to heavy Dec. rains, probably got at the under-dash grounds and fusebox... so now I've got the independant intermittent wipers again, plus my AC won't turn on (not even the fan)... ARRGH! To top it off, my blower fan (for heat and defrost) has kicked the bucket, seems like terminal failure (open circuit, and some bits look cooked).
So once again the only ventilation in my car is the windows, and I'm going to have to take the dash all out and swap in another fan motor. Hope I have a half-decent one laying around. I guess partly I hate doing all that when I know that even after all that work, it still won't exactly blow my hat off! But I've gotta have some ventilation, and those wipers are really embarrasing on a dry day. I mean hey, I drive the car cause it's fun, not because it's got al the electronic doodads, but simple crap like that...
Tigger937
PostPosted: Fri Apr 28, 2006 1:35 am    Post subject: Re: I hate recurrent electrical crap problems Reply with quote
I know the feeling. I too have been beset by a whole host of electrical problems. For the wipers, try removing the steering wheel and cleaning the contacts with electronic parts cleaner. Seems to have helped on mine.
For the AC, check the relay(s). Sitting in that damp weather for so long probably corroded the contacts some. Maybe just bounce them off the concrete a few times.
The blower motor........hmmmmmmmm. On my 931, it seems like the motor is accessible from under the hood. I've never tried to remove mine, but last year the shaft started squeeking and so I dribbled a few drops of teflon lubricant on it to quite it back down. It's been fine ever since.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
PostPosted: Fri Apr 28, 2006 2:46 am    Post subject: Reply with quote
LOL... yeah, I checked the relay already - so will have to get serious w/ the multimeter and wiring diagram, figure out what's missing.
Yes, the blower motor is accessible, but not removable (except maybe the '82-built cars; mine was built in '81, though titled as an '82), from underhood. I'll have to remove the R2D2 (HVAC) unit) and split it to get the motor out. Major overhaul. But I have to replace that R2D2 anyway, as the linkage for the fresh air flap is broken anyway. Already have a replacement.
On the plus side, my fabricator works at Bosch down the street in the body electronics division; he said he's got "squirrel cage" type blowers all over the place down there, and we can look at retrofitting one. I'll try and take pics, so hopefully we can try to share the procedure if it's not too bad, so others can do the same...
Tigger937
PostPosted: Fri Apr 28, 2006 4:39 am    Post subject: Reply with quote
Sounds ugly.
Looking forward to this. It would be nice to feel the hair blowing back on my head!
1981 931 (Concours)
das push
PostPosted: Sat Apr 29, 2006 12:15 pm    Post subject: Reply with quote
for the blower check the switch. the reason I say this is the wipers, brake lights, and the blower(heat/defrost) circuit run thru the switch. If you pull the switch you will lose all three.
now for a question to others for a little help with my blower. IIRC there is a resistor in the harness for the blower. If I'm correct does anyone know what I show for(value) resistance. I have continuity; blower runs if directly hooked up to an external power source but not through the harness. switch is new and functioning.
1982 924 NA 85K owned since 1992
82 nicknamed das push"the push"by my kids.
lots of electrical problems 1st yr of owner ship!
PostPosted: Sat Apr 29, 2006 6:20 pm    Post subject: Reply with quote
I have had 3 cars where the resistor box for the fan has died.
I managed to repair 2 but replaced 1.
Don't know the values though.
The units had got so hot the solder had separated.
(fans were tight but were greased before finishing the job)
Tigger937
PostPosted: Sun Apr 30, 2006 12:11 am    Post subject: Re: I hate recurrent electrical crap problems Reply with quote
Check the bracket weld for the fuel line next to the fuel filter for pin holes. Mine had 1 that was only visible with a work light illuminating the driver side footwell. Water would leak onto my fuse/relay panel from here. Sealed with RTV.
Maybe the blower motor shaft was lacking lubrication and this caused the motor to draw excessive current?
Whoops, guess you already knew that.
1981 931 (Concours)
PostPosted: Sun Apr 30, 2006 12:12 am    Post subject: Reply with quote
From memory, since I did check this of course (remember, I wrote the book on diagnosing electrical problems in these cars), I found 0-1 ohms on the full-on position (measured at the fan connection, between the ground wire and actual ground - remember that the fan grounds through the switch, and gets 12V as long as ignition is on). In the Low position (marked "I"), I found about 3-4 Ohms. Below that, in the variable section, it goes up to, as I recall about 30-40 Ohms.
Tigger937
PostPosted: Sun Apr 30, 2006 4:03 am    Post subject: Reply with quote
924RACR wrote:
From memory, since I did check this of course (remember, I wrote the book on diagnosing electrical problems in these cars).................
Nice work BTW.
1981 931 (Concours)
Stampedetrail
PostPosted: Mon May 01, 2006 7:05 pm    Post subject: Reply with quote
Fan motors often go belly up for whatever reason. Mine was not included. The one on it is from a VW jetta. I had to create a shroud for it, but I'd rather not discuss how that was accomplished. I'd start with ripping the fan motor out from the hood, not the dash, and find a good Bosch motor. One switch- on full blast or off.
1977.5 924 "Martini" head / New Old Stock rebuild
1985.5 944 Why? Because I can.
PostPosted: Mon May 01, 2006 9:56 pm    Post subject: Reply with quote
Sure, but this car is primarily a restoration car, to be kept stock. If I wanted power, I'd rig up a 12V ducted fan from a marine supply store - sold as a bilge vent fan. Those things pump serious air, are efficient, and compact. I'll eventually get around to installing one of those in the racecar (which, ironically, has a stock fan that works well).
Tightened the screws on the wiper switch - they were indeed loose, and I think that may fix my wiper problem. Unfortunately, I really need to replace the lock housing, as 2 of the 3 screw holes are stripped (explaining why they come loose). Also causes problems getting the high beams to work - since the whole housing moves when you make that motion.
Still haven't dug into the AC problem, but I have to go racing this weekend - will worry about that later...
PostPosted: Mon May 01, 2006 11:55 pm    Post subject: Reply with quote
You might get some more life out of the lock housing by re-tapping the screw holes. I did it (very carefully) - tapped to the next larger standard screw size and that's how mine's put together now. If you don't want to do it, send me your old one when you replace it!
PostPosted: Tue May 02, 2006 12:10 am    Post subject: Reply with quote
Not a bad idea...
Stampedetrail
PostPosted: Tue May 02, 2006 2:25 pm    Post subject: Reply with quote
Well there you go-- blower motor from the racer goes into this one, the bilge vent fan goes in the racer! Good luck at the track, & take some movies.
PostPosted: Tue May 02, 2006 10:21 pm    Post subject: Reply with quote
Unfortunately, that's not an option; the dash can no longer be removed from the racecar, due to the dash bar install - it'd have to be cut out. Or, at very least, I carve out the fan from the box via underhood access (not ready to do that yet).
Thankfully, the wipers stay put now that the screws are tight! Not so embarrassing to drive any more...
