Kenodog
Posted: Tue Apr 25, 2006 3:26 pm Post subject: Strange wiring |
So a strange thing happened today,the first in years,crap.
My car was hot (operating temp) and because the cooling fan was on when I used the power windows it blew the fuse. So while I was wondering why the window wouldn't go up (under dash checking fuse) my buddy told me that there was mucho smoke coming out the tail pipe.I check the dash and sure enough she's in the upper 3/4 of the temp gauge.
I turned on the aux rad fan,thankfully on a dedicated line,and drove home.No smoke once cool.However.After I cooled the engine alittle and restarted it the smoke out the tailpipe started again.Could this just be that the oil is getting too hot/thin and leaking into the compressor side ? _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Posted: Tue Apr 25, 2006 4:49 pm Post subject: |
What colour was the smoke?
Oil smoke has a distinct bluish tinge, and a distictive smell. Do you you get more smoke if you rev it, if not it's probably not oil blowing past the pistons.
Presumably your timing and fuel mixture are spot on? _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Kenodog
Posted: Wed Apr 26, 2006 2:44 am Post subject: |
It was oil smoke alright,you could smell that.I just took her for a ride and then stopped with the engine running to get it good and hot and the smoke didn't come back.It was definitely oil from the turbo that caused it because you could see it in the intake runner.Lots of it.
My guess as to what happened yesterday is that because the car was idleing low there wasn't enough oil pressure to keep the turbo cool,which in turn thinned the oil enough t o get by the oil seals.Then the window/rad fan fuse blew (still need to trace those wires) and she heated even more.More oil in the intake.Bottom lline is that I need to get a new turbo on the car.One that's water cooled and has 360 degree oil seals. _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Posted: Wed Apr 26, 2006 4:39 pm Post subject: |
Sounds expensive...  _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Kenodog
Posted: Thu Apr 27, 2006 2:04 am Post subject: |
Yep.The K26 may have been cutting edge 26 years ago but then hey,so was disco. _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
