isuras2
Posted: Thu Apr 20, 2006 2:44 am Post subject: RPMs |
Just wondering what RPMs I should shift at during normal driving conditions. I have been shifting at 3-4k, but might need to wait a little longer. It does sound like the engine is racing when I shift, but that could also be the loud muffler.
Thanks, _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
Posted: Thu Apr 20, 2006 7:56 am Post subject: |
what do you mean normal condition?
when you want to go slow you slowly push on the throtle and you shift under 3000 RPM
when you want to race you push the throtle all the way and you shift at 6000 RPM _________________ Supercharger and EFI kits
924er
Joined: 10 Jan 2006 Posts: 339 Location: Los Angeles California
Posted: Thu Apr 20, 2006 11:22 am Post subject: |
i think the best time on a normal condition is 3500, sumtimes i hit 4000. when i race i take it all the way until i hit the tip of the red line _________________ 80' Porsche 924 NA - Slower then a S L O W
86' Porsche 951- New toy |
Posted: Thu Apr 20, 2006 11:34 am Post subject: Re: RPMs |
| isuras2 wrote: | | It does sound like the engine is racing when I shift... |
These engines are pretty rough. No doubt a loud exhaust system doesn't help. But these engines certainly aren't the smoothest things in the world. Unless it's making some pretty horrible noises, I wouldn't worry about it too much. Just learn to live with it.
In normal traffic, I usually shift under 3000rpm. But traffic moves pretty slow through the city here. The only exception is first gear, which I usually let run to 3500-4000rpm. Not for the acceleration, it's just because the gear is so low that if you shift into second before that, it drops really low in the revs... and you get a soccer-mum in a truck up your arse screaming obscenities at you while the car struggles to accelerate You shouldn't have that problem with the NA.
I'd say just drive it comfortably. If you like giving it a bit of a rev, then go for it! If you want to drive for economy, use light throttle and shift early. You'll be slow, though
Paul did a poll on this not long ago... here. _________________ '80 924 Turbo |
Posted: Thu Apr 20, 2006 12:16 pm Post subject: |
For the racing while shifting (if it actually exists), you could check the throttle - make sure the return spring is there, plus give it a shot of carb cleaner or wd-40 to ensure that the throttle isn't sticking open temporarily instead of closing right away.
There's also a device called the deceleration valve (sometimes referred to as the anti-backfire valve) - this lets some air in, bypassing the throttle when the throttle shuts to give the engine a more gradual deceleration between shifts. As I recall, it affects emissions by eliminating a spike in NOx each time the throttle snaps shut, plus it eliminates the backfires that would occur otherwise.
Anyway- It seems at least possible that if this valve is malfunctioning, it could have the opposite effect and open too wide, causing the engine to over-rev.
The possibility of the distributors' centrifugal advance sticking may be another thing to look into. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Thu Apr 20, 2006 12:27 pm Post subject: Re: RPMs |
I read that wrong, didn't I?
I though you meant it sounded like it was revving harder than it was... sorry 'bout that. _________________ '80 924 Turbo |
924er
Posted: Thu Apr 20, 2006 1:17 pm Post subject: |
| Quote: | | and you get a soccer-mum in a truck up your arse screaming obscenities at you while the car struggles to accelerate You shouldn't have that problem with the NA. |
i feel you on that one khal, all the time  _________________ 80' Porsche 924 NA - Slower then a S L O W
